twin turbo chip ?
gtlegacy
twin turbo chip ?
Post by gtlegacy »
is there such a thing ?
ive just done a legacy ej20g ecu
i was just wondering if ther are any at all for the twin turbo and if they have the same type of set up for installing ie socket or you buy the socket with the chip and get it soldered in ?
if so are there any particular ecuswith the socket for the be5b48d model
if its nt in this forum can sumbody direct me in the direction
thanks muchly
napphappy
Post by napphappy »
I am confused by your question.
There is a large difference between the ej20g and any twin turbo ecu. The first is obdI and pretty simple. anything after that is OBDII and considerably more complex.
