Rob's 4to2 Igntion Converter
rob
Re: Rob's 4to2 Igntion Converter
Post by rob »
Mt.HOODrat wrote:i know i am excited about this, i just read up on robs ej20g thread, i was searching all over for a cheap tuning solution, and found his threads and was so relieved... but he hasnt posted in a month, im sure he's just a busy guy with a life and a job haha. although that would be unfortunate if he pulled a revtronix on us all haha. BSOD would have to write a "legacy of Rob" thread...
Dang...this thread too?
I don't have much to update. I am arranging to borrow a local donor car to test this on. I won't make it available until I have solid data. Bench data is one thing, miles on a real car is another. Hopefully I will have the car this weekend. No promises though. :)
-Rob
farfrumwork
Post by farfrumwork »
I'm in Seattle through the weekend. We're going to come to YOU! Now where is Puyallup from here? haha ;)
J/K Rob. We appreciate the efforts and your desire to make things right before they ship. Good luck with the testing.
Old - '93 T-Leg - 14.693 @ 92.68 at 5800ft ASL (Bandimere Speedway)
New - 07 Spec B/stg 2
"bloodstains - speed kills -fast cars - cheap thrills -rich girls - fine wine
i've lost my sense - i've lost control - i've lost my mind" Agent Orange
x2hawt4ux
Post by x2hawt4ux »
does this work with any ej20 turbo ecu?
92 turbo legacy: RWD W58 SWAP, td04, 3"tbe, mbc, fmic, wrx brakes/hubs, wrx seats, welded 4.11, fcd, drift steering wheel, Drifting Stickers
wtdash
Post by wtdash »
x2hawt4ux wrote:does this work with any ej20 turbo ecu?
Read back thru the 'EJ20G "RobTune" EJ20 thread for your answer....there's a list.
TD
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
rob
Post by rob »
I posted an update on the first page.
Thanks to Drew for dropping his car off yesterday. I have been out of town a lot last month. Hopefully I can wrap up testing of the prototype in the next couple of weeks.
-Rob
scoobylover57
Post by scoobylover57 »
Ill b buying one as soon as its ready [*]
-Nick-
91 lsi with ej22t swap. work in progress. Sold.
92 SS 5spd. stock. Sold.
94 TW. 6 spd. V2 sti ra ej20g. 550's. rob tune.
94 SS 5spd. stock
farfrumwork
^^ x2 (with chipped ECU as well)
yellow tops & JECs maf all ready to go... the transmission is scared! :)
LookAsubie
Post by LookAsubie »
farfrumwork wrote:^^ x2 (with chipped ECU as well)
Same here man, lol. Along with a 16g and a FMIC.
1992 legacy SS 5mt, Winestone Metallic.
rob
Post by rob »
Another update void of real news has been added to the first post :)
I thought you all would enjoy this picture. Yes that logic analyzer is about 10 years older than the car. lol. Have I mentioned recently how much I hate the fact that the ECU is right under the dash?
Have I mentioned how much I hate the location of the ECU as well? Not only it's whereabouts but the fact that it's jammed up there and pretty much requires disconnecting of other connectors below it just to remove it and the screws are ridiculously hard to get to.
I'm interested in this as well. But only if it will simplify my current dual ignitors-under-the-dash setup.
rob
Post by rob »
I finally figured out why the proto wasn't working correctly wired into the car. It was a tough nut to crack. Basically what it comes down to is that I didn't properly characterize the signals used between the ECU and igniter and made assumptions based on my experience with Toyota parts. Once I figured out why the chip wasn't behaving correctly, I dug out the O-scope and verified, which I should have done first thing! It is an example of sloppy engineering; bad on me! I need to add a couple electrical components and it should be good. Parts are on order and will be able to pick up testing in a few days. I also found the correct source for ECU connector crimp terminals. This will greatly simplify installation.
Awesome!
Would you mind sharing your source for ECU connector crimp terminals?
rob
Post by rob »
Certainly!
http://components.arrow.com/part/detail ... 42949N5665
Hurry, only 30k left in stock :D
You need a decent crimp tool to go along with it.
-Rob
Thanks Rob. Is there a specific crimp tool for these type of connectors?
rob
Post by rob »
BTW,
With the correct part numbers you can get all the connector housings and the ECU PCB mount connector as well. I don't have all the part numbers in front of me, but I picked up a spare of the 26 pin connector to verify. That part is;
http://components.arrow.com/part/detail ... 24738N1145
Yes this does mean cheaper DIY patch harness are possible.
-Rob
rob
Post by rob »
This is the crimp tool I bought. It seems to do a decent job. I am sure there are better ones, but this was fairly inexpensive.
http://www.phoenixtuning.com/zenstore/i ... i66u45k9f2
-Rob
That's good to know about the connectors & housings. That will definitely give some additional options for making your own patch harnesses.
I've got a craftsman crimp tool with several different crimp jaws that would probably work. I just didn't know if there was a specific tool for these little connectors.
Rob, need your converter!
rob
Post by rob »
kimokalihi wrote:Rob, need your converter!
Geez, it would be done by now if I didn't spend so much time chasing a certain someone's phantom knock problem :-D
I Keeed I keeed.
-Rob
lol my car died in heavy traffic again going up to seatac to take my friends to the airport. The road up there is pretty unforgiving with it's horrible bumps.
rob
Post by rob »
After yet another complete circuit re-design, I am happy to report my prototype is up and running. I don't want to jump the gun and call it done until I get some good road miles first, but all looks solid. It starts, idles and revs perfectly on both the EJ22T stock ECU and the EJ20G ECU. Once I am satisfied after driving it I will finish up my PCB design and order parts for production.
-Rob
Good the hear Rob. I've sent you a couple emails and a texts and I haven't heard from you in weeks. I need to know if I can run a twin turbo legacy JDM MAF on my car with your tune. I know it's a slightly larger diameter MAF and I don't know if it reads differently or not. I should have it any day and I want to put it in my car because it will allow me to go back to a factory airbox setup and ditch my cone filter.
rob
Post by rob »
Hey Kimo,
I was out of town nearly all of last week. I'll ping you on email later. In general, no don't use a different MAF, and the stock ej20g green MAF fits the stock airbox just fine. I have swapped one in myself on Drew's car. Perhaps it deserves it own thread and I can post pictures.
-Rob
That's the problem, I'm not using the stock airbox since I have under-the-manifold intake. I'll email you.
