Got an alternator from a 06-07 B9 Tribeca from my mechanic, score! Includes the 3pin connector and pigtail. I'll take a photo...anyone know what the three pins/wires are for?
Looks like it has:
Black with red stripe
White with red stripe
White with black stripe
...or did I perhaps end up with a different 3pin connector pigtail here not for an alternator?
Any idea on the amperage rating on this thing? Not really sure what model year it came from, it was sitting in a pile of spare parts that were likely good. Says Mitsubishi on the alternator itself, hmm...sure looks like it will fit right in place no problem. Although it looks like I'll have to drill out the existing ring connectors to fit around that huge bolt... and find a nut to go on top, as well. That's a ground, right? Should I also run a new cable directly to the battery's ground while I'm working with this part? I plan to do the grounding mod soon to this car anyway, if that's a ground then I should probably include it.
