Hi everybody,
You know, in France, there are lots of limited speeds, and it is not always possible to conserve a look on the speedometer ! I have to choose... between the road and the speedometer !
So, I'm thinking about the possibility to make fit the genuine cruise control you receive in USDM cars...
And I would like to know if it is possible, and which parts are needed, or if it is not possible.
I searched on the forum before posting, but if I found lots of things, I did not have the answer I need.
I hope, you will help me !
Thank you very much !
cruise control on a french car ?
Re: cruise control on a french car ?
i found some of the parts its getting hard to find the older cars to get the wiring. i'll keep looking around
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
Marc,
I think the first thing I would recommend checking is to see if there are wiring connectors where the vacuum pump would be on the passenger side of the car near the AC receiver-drier and to the right of the glove box for the cruise computer. If the wiring is already there, you should be able to just get the components: pump, actuator, computer, switch, etc and plug everything in. If the wiring is not there, it will be a much more difficult task to do.
