So I am merging my impreza harness with a 22t harness. I am trying to figure out which plugs on the legacy side I don't need. I have a wiring diagram for the legacy but it sucks. Not sure if there is another diagram out there that is scanned better and has a listing for what each plug is. Here is the page I am talking about.
It would be great if someone could label those for me or give me a link to a wiring diagram that is complete.
95 Impreza EJ22T Wiring Merge
Re: 95 Impreza EJ22T Wiring Merge
Looks like the diagram I have is missing a ton of pages
Unfortunately the wiring diagram on my site for the ej22t is not complete. Not sure if that's what you're using. If not, check out the stuff you need to know forum to d/l what's on my server.
Are you just looking to merge the engine harness? Does the Impreza have the engine wiring harness behind the battery or coming from the firewall. If it's coming behind the battery, it'll be a much easier swap/merge.
If you can provide some additional details on what you are looking to do we can provide some guidance.
