Does anyone know where exactly the power window circuit breaker is? I'm looking for a picture of it.
Is it under the carpet under the drivers seat, or is it next to the power window motor in the B pillar pocket?
Also, how is it reset properly?
Power Window Circuit Breaker
Re: Power Window Circuit Breaker
Under the carpet under drivers seat, and it auto resets.
64-1 is the diagram you want to look at. (Diagram courtesy of josh)
http://www.surrealmirage.com/subaru/fil ... tion04.jpg
Charles
rallyak wrote:Under the carpet under drivers seat, and it auto resets.
Thanks, so if it auto resets then my windows aren't working for another reason.
I had an issue with mine. The electrical plugs down there get water into them over time, usually from a leaky sunroof, but also from degraded door seals. I took my plugs apart and cleaned them best I could. And put dialectic grease around the contacts so water couldn't get in. That solved the problems for me, at least till my driver window motor died.
mike-tracy wrote:I had an issue with mine. The electrical plugs down there get water into them over time, usually from a leaky sunroof, but also from degraded door seals. I took my plugs apart and cleaned them best I could. And put dialectic grease around the contacts so water couldn't get in. That solved the problems for me, at least till my driver window motor died.
That's exactly the problem I ran into. Heavy CA rain created a lake in the back seat. I'm gonna roll the carpet and really get into it.
