»  BC-BF Legacy Discussion »  Electrical
#at/mt swap b48 pin 20
Custom Search
Login | Register
Post new topic Reply to topic  [ 2 posts ]
Author Message
 Post subject: at/mt swap b48 pin 20
PostPosted: Sat Jun 10, 2017 4:02 pm
hey guys, just wrapping up my 5 speed swap into my 1992 a/t legacy ss.
anyways, i am just making sure that i have the right pinout.
there is no wire in this spot, so i am assuming in need to run a wire to ground for this one.
anyways, here is a picture, i just wanted to double check that i have the right spot on the plug, the one with the red dot is the pin i think should be the a/t m/t identifier pin.
here is a pic of the slot i pulled the plug from on the ecu
Profile  Offline
 Post subject: Re: at/mt swap b48 pin 20
PostPosted: Sat Jun 10, 2017 11:01 pm
nevermid, i figured it out, i was looking at it wrong
Profile  Offline
Who is online
Users browsing this forum: No registered users and 4 guests
Panel
Search for:
Jump to:
Dizayn Ercan Koc
