Economical Scanner
legacy1992
Economical Scanner
Post by legacy1992 »
Can anyone recommend a economy handheld scanner that would work for my 92 and 98 legacy, thanks.
Alphius
Re: Economical Scanner
Post by Alphius »
Scanner, like for reading engine codes?
None will work for both cars.
On the 98: It's OBDII compatible, so any cheap parts-store code reader will work.
On the 92: See here for the procedure on pulling codes from the ECU:
http://www.surrealmirage.com/subaru/engine.html
