New engine update.....
My Paeco long block arrived Thurs. with all the new pumps, idlers, gaskets, etc. Ordered my Magnecor wires & they should arrive next week along with the custom intake, fuel filter and oil pan. Joel @ PDM (in Co.) has been a great help & along with Al`s suggestions, I should be in fat city! Here`s a breakdown as to what I`ve done so far and the next few steps after the engine is running (week of June 9th.) here goes....block is bored .040 over w/ 1/2" stroke-Arias 9:1 forged pistons with thermo coating-chrome moly steel rods-hard chromed crank-retained oil squirters-crank line bore checked-upgraded bolts throughout-copper head gaskets-heads had CCs checked-bronze guides-SS valves and seats-titanium retainers-upgraded valve springs to match torque cam-intake modified to parallel fuel feed with a billet, dual outlet fuel filter + extra port for additional injectors (if needed later)-380cc injectors were cleaned and balanced-turbo MAF to be added to operate injectors w/stock NA ECU-Walbro 255 lph fuel pump-new sending units for both tanks-Vortech RRFPR with stock FPR (for idle-will not be needed once the Unichip is installed)-stock TB (for now-will need more research before this mod is done)-MSD #6212 DIS-2 ignition w/boost timing master and rev control-modified air intake with K&N filter and i/s & o/s of air tubes from filter to TB thermo coated-2.25" up/down pipes with bellmouth and wastegate divider in DP-boost controlled alcohol injection (metanol or denatured) with manual volume control-Blitz turbo timer. Other upgrades include an Optima battery, JMO convertor, TransGo shift kit, upgraded trans cooler and factory filter system. All fluids are Redline synthetic including their water-wetter mixed with distilled water and upgraded anti-freeze (motor will be broken in with dino 10w-30 oil and changed 3 times in the first 1k miles.) After approx. 8k miles, the 10w-40 redline will go back into the crankcase. First mod after running will be another hi-flow cat and straight-thru 2.5" exhaust system. If you`re in the area, I have a Dynomax straight-thru muffler for you that`s in excellent shape. Next, the Unichip that will have drivers for boost, fuel, timing, etc. It`ll have 2 maps that are switchable between 91 octane settings and race gas. Next will be the 550cc injectors tied in with the Unichip install. Finally, I`ll add an IC once my turbo hood is modified for better air flow. BTW, I had reported before that I had a Garrett T20 turbo-wrong! It`s actually a T28 that`s designed for quick spool-up with a 60 AR for top end. It`s good for between 350-400 hp. I`ll keep everyone updated as to how each upgrade has helped and if it was worth the $$$. Sorry for the long post--Almost Running Rod
Age and treachery will overcome youth and skill!
I just got a new digital camera and have a scanner, so once the car is cleaned up I`ll post some underhood and outside pictures. BTW, anyone in the NorCal area familiar with a cryo-treating facility in our area? I have the WRX front brakes and turbo rears ready for some treatment. Also, the guy that did my thermo-coating also does calipers and rotor hats; helps keep heat away from critical parts of the braking system. Another question: is anyone going to the SEMA show and the west coast Subaru meet this year in early November? Let me know as I`m ordering my tickets (as an associate with Forced Air Technologies.) Some of you may think I`m either rich or stupid or both for putting so much into my car. I`ve been doing this to some degree since 1962 and can`t think of a better way to spend my money. I`ll be 59 this Nov. in age and 25 in spirit. If I can help by trying different things before you guys do, maybe I can save someone some grief. Enough said---Rod
Well said Rod. For cryo-treating, you may want to ask the same question on the i-Club or NASIOC. Try posting it in the Bay Area section, as I'm sure some of those guys can point you in the right direction. I may be heading out to SEMA, I'm just not sure right now. When's the west coast meet anyways?
-Brian
-Brian
'04 PSM FXT
Rod if you don't mind shipping the place up in tacoma, wa I used is good.....but I understand your desire not to want to pay for shipping
