Okay, I've searched through the forums and here's the post I'm referring back to for any who don't know.
http://bbs.legacycentral.org/viewtopic.php?t=989
So the issue is getting the "vent to atmosphere pssshhhhh" sound but not have the issue of running rich, like crap, etc when drving around town. I need a compromise for my rally car which also uses and MAF system and here's what I've devised to be able to run a TRUE atmosphere OR recirc valve.
Take any recirculation valve and locate the piping that recirculates the air back to the turbo. Cut this line in the middle somewhere where it won't touch extremely hot stuff and you have a little bit of room.
You now have two pieces of pipe, one from BOV, one from the preturbo inlet.
Working from the preturbo inlet side of pipe first install a switch valve that allows you to close or open the pipe. Attach another piece of pipe (a few inches) and connect back to the pipe going to the BOV with a T connection. Add an inch or two onto the T and put on another On/Off Valve then another inch or so of pipe and then one of those little small air filters, kinda look like a small cone filter.
You are done. Make sure to note and mark which way is on and which way is off on the two valves you installed.
Here is pics:
http://www.hugheshometheater.com/Photos ... bovsys.JPG
The little air filter is mostly a safety precaution.
Here's how it works. Normal city driving, close the valve at the filter (valve 1) and leave the valve (valve 2) going back into the turbo inlet open. You are now on a strictly recirculation BOV system. Close valve 2 and leave valve 1 closed and you could see how your car would run without a BOV but I wouldn't recommend trying this. Now leave valve 2 closed and open valve 1. The BOV should now vent to the atmosphere, and you will still run rich and have problems idling most likely but you can get that cool sound you wanted (useful down at the beach pickin up girls, wait I'm in Colorado so nevermind that). From a rally car stand point I can now test both ways and play with other things to maximize performance on stage, but still be able to drive around town, where with decals I always have to drive slow. The air filter is there so that if you leave both valves open and start sucking in air, it's at least filtered air. Anyhow, let me know what you guys think.
Another option I jsut thought of would be a way to find some way to push filtered air back into the system before the turbo while still venting to atmosphere as to keep the readings from MAF and actual readings close. This would be a much more difficult task though and I've been doing Probability Theory homework all day and my heads starting to hurt. Good night.
Found Compromise for BOV Atmosphere and Recirc issues
Grant Hughes
Denver, CO
http://www.nocoastmotorsports.net
Denver, CO
Why not have a valve that's infinitely variable so you can get as much sound or performance out of it that you want. That would make it similar to the hybrid BOV's they have now, but more advanced (hybrids atmosphere high pressure and circulate low).
Re: Found Compromise for BOV Atmosphere and Recirc issues
A simple question: why do you NEED your BOV to vent to the atmosphere for the rally car?Grant wrote:I need a compromise for my rally car which also uses and MAF system and here's what I've devised to be able to run a TRUE atmosphere OR recirc valve.
-Jason Grahn
You like that pic eh. I'm a true artist.
I don't NEED a vent to atmosphere BOV for my rally car but I do need a BOV and with this method I can easily change between the two and determine which method maximizes power output. If it happens to be to atmo. I can leave it recirc most of the time and switch it as needed. Currently I have no BOV at all on the car so that's why I'm looking at this issue. I personally hope the recirc is the best because then I have a true sleeper.
Grant Hughes
Denver, CO
Denver, CO
