I installed the Hallman Pro RX MBC on my 91 SS. With the soft spring I can run about 10psi...with the stiff spring...it only runs 10 psi as well...all the way cranked down.....
I am stock all around....what are results of others using similar MBC's?
I was thinking that maybe the exhaust is limiting the boost
Hallman Pro RX max boost?
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
16 WRX | 6mt | fa20
How have you hooked up the boost controller?
The bottom tube I spliced into the line coming off the intake manifold...the side tube to the wastegate....capped off the turbo nipple.....that's it
it definitely works....but can't go over 10psi
maciek puszynski
16 WRX | 6mt | fa20
16 WRX | 6mt | fa20
Should work. I have a Hallman, I think the exact same model, and I was up at 12-13psi no prob.
As a separate issue: Don't plumb it off the intake manifold, plumb it from the compressor to the MBC to the wastegate. That way you won't overboost the turbo at part throttle. Doesn't answer your question, though.
'00 Impr RS - sold
You mean from the turbo to the MBC to the wastegate?
maciek puszynski
16 WRX | 6mt | fa20
16 WRX | 6mt | fa20
yes, the nipple on the compressor side of the turbo
'00 Impr RS - sold
Not familar with the hallman, but if there is no bleed/vent of air you will not be able to increase boost (MBC's are just adjustable boost leaks).
If there are just 2 fitting on your MBC with no vent on its body then 1 of the fittings is the vent.
I have a cheap-o e-bay MBC in the LSS at the moment & I "T'd" 1 fitting into the line going to the wastgate, the other fitting was left disconnected (or connected to the coffee-mug) as it is the vent that allows you to raise boost.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
96 Impreza OBS
99 Impreza OBS-T
Nope. Disregard what BXSS said. He is correctly speaking about one type of MBC, but it's just that he doesn't understand how a ball-and-spring MBC works.
'00 Impr RS - sold
