Manual Boost Controller install, W-Pics (some Q's still)
ok so i have this boost controller
i really just need to know what gets run where from where, as im rather confused.
im looking at DLC's hbc write up right now, and still a little bit lost.
and the wastgate (actuator) is the thing with the 3 sticker on it in our cars correct?
im searching, i know..
Last edited by SubaruNation on Tue Mar 18, 2008 12:54 am, edited 2 times in total.
update, so i run the line (rubber one) you see in front of the air box and connect it to where the arrow is on my boost gauge (it says connect to wastegate actuator) and connect the other side to the wastegate right?
AKA here
eh?
i know im not the only one on here too much
AKA here
eh?
ok so this is the bottom of the actual boost controller
this is the bottom of the T that came with it.
this is the boost controller mounted
this is what the rest of the T looks like..
and the rest of the my pics are here..
http://gallery.legacycentral.org/v/Memb ... ost+Gauge/
i know how to put it all together, im just confused about what goes where.
i think the arrows don't help
this picture is my best guess, it shows the airflow from one area to the next.
if somebody could let me know if im right here, that would be great.
i really want to drive it.
the really really long red arrow goes to the wastegate, which i have a picture of above also
I used that same MBC on my SS for a little while.
I dumped the "t" that came with the controller because it has too much of a restrictor in it & caused big spikes - 20psi...
I used a plastic "t" with a 1/8 & 2 x 3/16's ends I got in a assorted box from autozone.
1 big end was connected to the turbo outlet
1 big end connected to the MBC in
Little end to the actuator
Other side of the MBC (top of your pic above) was left disconnected (its a bleed valve so needs to have 1 end open in order to increase boost), but you can connect it to the resonator/c-cup between the airbox & turbo if you like.
Make sure you start in the fully closed position which should be w/g boost if everything is connected OK.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
96 Impreza OBS
99 Impreza OBS-T
YEAH!!!!TheSubaruJunkie wrote:
Thats how you should have it hooked up.
Dont use that T. Directly under the wastegate is another nipple comming straight off the turbo. Plug that into the arrow, the arrow shows flow direction to the wastegate.
Hope you have a boost gauge.
finally!
thanks alot, oh.. i have a boost gauge
now to take some drifting videos
At least you used the good zip ties. Now cut them flush, dammit! The telcom and marine mechanic in me is going nuts.
ha ha i know, for some reason.. i dont know why.. i tend to leave a little extra to cut my hands on all the timeevolutionmovement wrote:At least you used the good zip ties. Now cut them flush, dammit! The telcom and marine mechanic in me is going nuts.
i was in a hurry and i wanted to drive it.
but now i'm scared to drive it.. is this normal .
it still needs some fiddeling but i think im going to get gas before i do anything else
so far i've got 130 miles on 3/4 of a tank of gas... most of that is from when my self fab'd 90* inlet made of electrical tape and radiator hose pieces ripped apart, and i didn't know about it for 15 miles but it killed my MPG.
awesome
This is what it SHOULD look like
here's STiPro's setup if you want to use the T.
if you like having gas in your tank dont. ha ha
but otherwise do, it's SWEET!
and one more one last thing,
the line that goes from where my resonator would be, to the bottom of the stock boost control solenoid.
where should that line go with this new setup?
should it stay there because i didn't do anything with it..
This is the way it should look in your engine bay
Just remove it because you have bypassed that system, and its not required.SubaruNation wrote: and one more one last thing,
stipro's set-up is the correct way to connect this.
+ & - will work as they are supposed to & you will not get retarded spikes @ boost levels that should be held steady.
Subarujunkies's set-up will not work properly.
Fully closed "- " (less boost) on the knob will not allow air to pass to the actuator which is the same as disconnecting you turbo to actuator line - maxing out boost.
Open "+" (more boost) on the MBC will give you less boost, but you'll get a spike that tapers to actuator boost.
There is no way of getting around using the "t" - thats why it comes with the controller.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
96 Impreza OBS
99 Impreza OBS-T
