The above is basically the 2 stage set-up I figured out & had SubaruNation post up a while back using the OEM boost solenoid as the the base boost level rather than the actuator.smh0101 wrote:So, after installing my IC, vf10 and 440cc injectors I found myself driving around town... a little fast... and maybe... always in boost lol... at about 15lbs, that, uh... DRINKS gas.
So I wanted to create somthign that would let me switch between Low Boost and High Boost whenever I wanted. Someone posted about doing something with a MBC and Wastegate Boost... But honestly, wastegate was lower than what I wanted for my Low Boost setting, I wanted to be able to switch between my MBC and the Stock Boost Controller.
So here is a diagram of what I created.
The Solenoids are from a 1st Gen Legacy. You can get them from a JY, it takes on 12mm bolt to get them off, they are mounted right below the passenger side intake runner and hookup to the Charcoal Canister... I believe they are called Canister Purge Solenoids.
I had created the Diagram awhile ago, then i built it 3 days ago and have been using it around town...
ITS AMAZING!! I love it... getting about 23 mpg on Low Boost. And killing Hondas on High!
So the Low Boost Setting I'm running 8.7psi
And on the High Boost Setting it runs at 16psi
The only warning for anyone wanting to do this... If you accidently leave the switch in the middle, off position... You will have NO boost controller connected to the Wastegate.
So make sure that you dont do that and your good!
What I'm going to do is put two lights on the dash above the center vents, one Yellow/Orange for Low Boost and one Green for High Boost. That way you know if it isnt sending proper signal to the Solenoids.
http://bbs.legacycentral.org/viewtopic.php?t=36506
I actually said my set-up could be improved upon with more solenoids / MBC's but I was thinking 2 MBC's & 2 solenoids on a 3 position switch that would give you 2 boost levels you could SET (10 & 15 PSI, 12 & 20psi).
To get this done -
Basically just replace the stock boost solenoid in the above diagram with a MBC & plumb in a charcoal canister purge solenoid as shown.
NOW You'll have 2 user selectable boost levels to choose from.
On TD05s or TD04s with 8-9psi actuators my old set-up & the above slightly improved set-up are basically the same - which is why I never used the stock solenoid for a base boost level as I was on a TD04 when I figured the whole CHEAP/Free 2 Stage thing out...
BUT
Good thinking on the stock solenoid idea any way - good for the VF11 guys!
I'm currently on a old HKS EVC which gives me 4 stages of boost, actuator level as a base & 3 levels I can select (off, low, med, hi) so its up to you guys to try this out & improve on it!
