Trying to put my 94 turbo legacy together.I didn't take it apart and the fellow who did is gone. I am having fun.
1. how many bolts hold the chimney on and where are they. I see 3 holes but no threaded holes for them.
2. Anyone know where I can get that little u shaped hose right under intake manifold at the front. Dealer just acted stupid when I called. Nearest one is 100mi.I am going to play hell trying to figure where all the hoses go.
Allan
where does it go.
Re: where does it go.
Welcome to the BBS.
I would suggest you check out the stuff you need to know forum. There's a lot of good info/links there, including links to the service manuals and parts book. The parts book is pretty detailed with exploded diagrams of how things are put together. It also has the part #'s so you can use one of the online Subaru dealerships at a pretty significant cost savings. I have been using www.subarugenuineparts.com for quite some time. www.subaruparts.com is another.
http://bbs.legacycentral.org/viewtopic.php?f=12&t=14485
http://bbs.legacycentral.org/viewtopic.php?t=30531
Thanks to Josh for info on where to get it. Also many thanks for parts list. What a job.
Allan
Allan
