VF28
Posted: Sat Feb 04, 2012 2:01 am
by Mt.HOODrat
i have the opportunity to buy a vf28. any guys running one?
my question is could i get away with running this turbo with the stock ecu and stock injectors? from my understanding it is bigger than a td04 but smaller than a 16g.... what do you guys think? will it be fine if i run 10-12 psi?
my other mods will be 3'' turboback, and a TMIC.
Re: VF28
Posted: Sat Feb 04, 2012 6:40 am
You should be fine running 10-12 psi. You'll probably want to get a wideband to check your AFR's out to make sure you're not at the edge of your MAF & injectors. You'll be close, but should be ok.
Re: VF28
Posted: Sat Feb 04, 2012 7:36 am
by Mt.HOODrat
what does the stock boost controller allow? will it be fine at stock boost levels?
Re: VF28
Posted: Mon Feb 06, 2012 6:54 pm
Stock boost controller is around 8-9 psi or so. Yes it'd be fine at stock boost levels.
Re: VF28
Posted: Tue Feb 07, 2012 6:52 am
by Mt.HOODrat
cool, yeah i hoped id be good at those levels, i was aiming for a td04 but i got ripped on a couple.... last time i buy from someone with no feedback...
then i found this vf28 from a guy on nasioc, had a ton of great feedback so i took it. it was crazy cheap, only a little bit for more than what a mint td04 was going for, plus it had a 90* aluminum elbow inlet welded on! so yeah, im gonna take it easy for now at stock boost levels, but when i save enough cash, these are my plans:
i just got this turbo, 06 tmic, and a 3'' downpipe and a 3'' straight pipe. then, i want to save for yellow tops, robs tune, and do the snorkus and coffee cup mod...
any guess what i would put down at the wheels with these mods?
stock 22t longblock (for now)
vf28 at 14-16 psi (or what ever the robs tune is programmed for i guess)
06-07 TMIC
3" turboback (no cats/muffler)
yellow top sti sidefeeds
desnork/CC mod
JECS maf
= ???awhp?
i know my slushbox will get grenaded (4eat) but i plan to do a wrx 5 sp when i can.
Re: VF28
Posted: Tue Feb 07, 2012 6:40 pm
You'll probably be in the 200 hp range
Re: VF28
Posted: Tue Feb 07, 2012 9:10 pm
by Mt.HOODrat
Really? That's weak... Is it the heads that are the limiting factor?I figured I could make more than that...
Re: VF28
Posted: Tue Feb 07, 2012 10:19 pm
Drive train sucks up a bit of power. Even on the STi's, which are 300 chp, will dyno around 250 whp. Or at least where I had my car dyno'd. That's 50 hp just in drivetrain losses!
So to get 200 whp, you need 250 crank hp. It just takes more money and specific parts to make big power on Subarus.
I will however say that just because the numbers aren't big, doesn't mean the car won't feel fast.
Re: VF28
Posted: Wed Feb 08, 2012 1:46 am
by Mt.HOODrat
yeah i imagine it will feel fast/be a fun car...
we'll see, its all coming together.... i just wish i had another car to drive while this one was down, it would make everything so much easier haha
Re: VF28
Posted: Wed Feb 08, 2012 6:37 am
by mike-tracy
160chp to 250chp, hell yeah you're gonna feel it :)
Re: VF28
Posted: Tue Mar 13, 2012 4:09 am
by CAV3MAN227
Legacy777 wrote:I will however say that just because the numbers aren't big, doesn't mean the car won't feel fast.
-I agree with that. The dynolicious iPhone app told me I was putting down 167whp an I'm happy with that, tho I do want more!
-Joe
