does anyone know how to pig tell the ECU for more boost ?
Mraolguy
Post by Mraolguy »
Just looking for a little info about boost i hear that you can pig tall Something to increase more boost, also i would need bigger injectors at that point i'm guessing any info on those would be helpful as well
For a Ej22t )
robertpaige
Re: does anyone know how to pig tell the ECU for more boost
Post by robertpaige »
I don't know anything about a "pigtail". My guess would be to not screw with wiring to get more boost, not even sure where to start with that. You can just get a Manual Boost Controller and you'll be set and can control it to your wish. If you go past 10/11psi you'll hit fuel cut for sure but you won't need to upgrade injectors to bump up boost. You will need a tune if you upgrade injectors.
Yeah, as Robert mentioned, a manual boost controller to up the boost to around 10 psi or so is the cheapest and easiest option that won't require injectors, ECU, MAF, intercooler, and other supporting mods.
Mraolguy
Post by Mraolguy »
that's a good idea and i'll look in to that for sure. Would you happen to know what the stock Psi for a Ej22 be? someone told me its like 5 Psi or something like that?
robertpaige
Stock boost on the EJ22T is 8psi.
Alphius
Post by Alphius »
To be more precise, stock boost at sea level is set to a peak of 8.7psi.
robertpaige
Thanks Alphius, I knew it was somethin like that. ;)
Alphius
Post by Alphius »
Haha, no problem. Always here to help. ;)
matt00rs25
Post by matt00rs25 »
I hit 10-11 all the time with occasional fuel cut. The problem with upping the boost on the vf11 is that's its out of breath so fast it becomes really pointless. Get a bigger turbo and injectors/robstune and such.
Alphius
Post by Alphius »
Yep. You basically have two easy and cost-effective builds to do with one of these cars. Not much else makes sense at this time.
1. Leave it stock, just make sure it is tuned up and running well.
2. RobTune with the following parts:
550cc injectors
JECS MAF
VF39 or TD05-16g turbo
06-07 WRX intercooler w/recirc BPV
Manual Boost Controller at 17psi
Free-flowing exhaust
Stock intake with de-snorkel and coffee cup mod
Either of these setups are fairly easy and will get the most bang for your buck. If you want more than the RobTune can give you, then it is time for a standalone ECU and at that point you should probably know what to do on your own. :D
