Larger turbo.. GT35
92ss satinsvoice
Larger turbo.. GT35
Post by 92ss satinsvoice »
Ehm,
Any one run a GT35 on one or our legacy's before?
I know its been done too much on STI's so I think its time we have a sedan on our board with one equipped.
Andy
Andy
94 L n/a 5spd, Rip
91 ss champagne - Rip
88 Leon GL Hatchback - DD
92ss satinsvoice
Re: Larger turbo.. GT35
Not a one huh?
alright, well my turbo is on its way. I'll post a picture when I receive it.
standby...
Andy
94 L n/a 5spd, Rip
Trailblazer ;)
92ss satinsvoice
you got it Mike.
In order for anything to expand from the norm and hit new level's of achievement, there has to be that one person willing to think out side the box.
you know, why not? :wink:
Andy
94 L n/a 5spd, Rip
How big is it? Have you looked at the compressor map? I'd check to see if its going to be efficient with your engine first.
robertpaige
Post by robertpaige »
The 35r is a big fuckin turbo.
Excited to see this :)
James614
Post by James614 »
kimokalihi wrote:How big is it? Have you looked at the compressor map? I'd check to see if its going to be efficient with your engine
Or he could mod/tune the engine to be efficient with the turbo. That thing will make some serious power, but it will take more than a Rob tune to make it work well...
wtdash
Post by wtdash »
kimokalihi wrote:How big is it? .
Comparison:
TD04 vs. FP RED vs. GT35r
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
DAMN!
robertpaige
Ohhhhhhh girl.
Me likey.
GClark
Post by GClark »
I got a 30r on my wagon. Sounds amazing, hits hard, and looks impressive.
1994 Legacy Touring Wagon
subytech
Post by subytech »
My buddy ran/is running a Perrin gt35 kit on a stroked 22t block with 20g heads, lag isn't bad, relatively lol, but it hits like a goddamn freight train, I love his car, too bad he is being forced to sell it :(
92 Legacy Turbo, 5sp MT, Early Large CC 20G heads, Ported custom clocked td04, Cobb catted DP, Injen SS 3" exhaust, Turbosmart MBC @ 10psi, Apexi 20g intake, custom FMIC, Fidanza 11lb flywheel, stock 05 WRX clutch
92ss satinsvoice
Ya it's getting up there in turbo size. For a four banger it's a nice size.
For power yes it will make a good amount. The heads I will be installing a set of cams
Along with springs and retainers from GSC. The bottom end of my motor is already built and I'm running a stand alone engine management. My clutch is rated for 525 ft trq so I'm good there.
The only thing I have that I will have to worry about out is the transmission and rear diff. Maybe axles too. I blew my second transmission last summer on lower power then what I'll be shooting for now. I have a pair I haven't swapped in yet also.
The turbo coming in is a gt3576. I was going to run my holset hc1 on my sedan as I won't be using it on my supra.
Maybe a 6 spd is to be in order. Haha!
Andy
94 L n/a 5spd, Rip
subytech
Post by subytech »
Yea my buddy's car originally had STi running gear and an Exidy twin plate, he is running modded STi injectors but he was going to get some "real" injectors before he had his final tune done. He is still running a Hydra with a break in map, its only got about 600 miles on the engine. Like I said too bad he has to sell it, but yea fun set up for sure, especially with the 60/40 torque split the 6sp has with no controller, thing did some nice slides before the 6sp came out!
robertpaige
Subytech, is it a wagon?
There are two wagons for sale on CL in Seattle.
One is black with a stroker build, fmic and rotated turbo setup, 6 spd, and race seats. The other one is a dark blue with a 6spd and 2.5RS six spokes.
92ss satinsvoice
Well, I'm pretty disappointed in the turbo that came in the mail.
The seller stated and I quote "Turbo has very little shaft play". To my dismay he was full of s***. It needs a rebuild.
It was also damaged during transit, the comp housing inlet has a spot that's bent. But any who I looked at the cop wheel and found out it runs the same wheel as the GT3776. 55mm or 57mm inducer and a 76mm exducer. From what I've been able to find is this turbo will be quite limited on power sense the exducer is only a 76mm and the power level is equivalent to a 30R. Since this thing needs a rebuild and a diffrent exhaust housing I might see if I can't track down a 3782 comp wheel and housing if not, I'll look into 3794R wheel.
So as of right now I'll be limited to around 400whp which is not enough because i'm am almost there already with my setup right now. I'll post pictures when I get a chance.
Andy
94 L n/a 5spd, Rip
James614
Post by James614 »
Its complicated how the sizing works on those turbos. Good luck with gettimg it all sorted out.
Do you have a build thread somewhere with your current setup?
92ss satinsvoice
Garrett turbo's are actually quite simple to understand compared to other types of turbo company's.
but if turbo's are new to anyone it can seem like a mess of numbers.
Yes sir I do have a build thread: http://bbs.legacycentral.org/viewtopic.php?f=25&t=35651
My progress with my car has slowed since I purchased another project that I have been working on for the past two years. But I would never get rid of my sedan over my supra. my Subaru is my baby.
Andy
94 L n/a 5spd, Rip
92ss satinsvoice
Well I received the turbo and its a pile of dog s&*$. I'm going to go another route that will net the same type of power with faster spool. This turbo cost more then what I bought the car for.. As of right now I'm waiting for a reply from Boost Lab to see if they can help me get what I need
FP HTA 3076
Also a Tial MVR 44
Should prove to be interesting. should check it out
Andy
94 L n/a 5spd, Rip
Can you elaborate why it's a piece of dog crap? Do you have it on the car or is it just a pile based on how it was built?
92ss satinsvoice
Josh,
My comment was kinda vauge. The turbo I received is just not useable unlessi want
To rebuild it. The GT3576 is a great turbo, I was just saying mine is crap. Haha
I received my quote back for the parts totaling: $2,199.00
Oh lord when will it end!
Andy
94 L n/a 5spd, Rip
Ahh...ok.
92ss satinsvoice
Here is the thread on the bad gt3576 turbo I received if anyone
Is interested in why I changed my mind.
http://www.supraforums.com/forum/showth ... el-Cashflo
I stopped by ETS yesterday and pulled the trigger on the parts. I also contacted John Reed at PSI about getting my car tuned.
But we are working on that. This cars gonna rip!
Andy
94 L n/a 5spd, Rip
Have to be registered to see that page
92ss satinsvoice
ah shoot. I can copy and past the whole thing if you would like! :-D
Andy
94 L n/a 5spd, Rip
