»  BC-BF Legacy Discussion »  Turbo
#loud TDO4
Custom Search
Login | Register
Post new topic Reply to topic  [ 16 posts ]
Author Message
 Post subject: loud TDO4
PostPosted: Wed Oct 15, 2014 5:18 am
i noticed that the jdm tdo4 sounds like a super charger when it its in boost. is that normal? it holds boost fine and kicks in hard
Profile  Offline
 Post subject: Re: loud TDO4
PostPosted: Wed Oct 15, 2014 5:41 am
dentist drill sound? Sounds blown to me
A4 LM7 Drift build: http://www.audizine.com/forum/showthrea ... or-shut-up
Profile  Offline
PostPosted: Wed Oct 15, 2014 5:48 am
more like a whipple super charger sound. it doent smoke boost kicks in better than my old vf 11 and holds 12 psi of boost til i let go of the throttle
Profile  Offline
PostPosted: Wed Oct 15, 2014 5:57 am
Still probably has a bent/chipped fin. As long as its not smoking and is holding boost, it should be fine!
Profile  Offline
PostPosted: Wed Oct 15, 2014 6:03 am
they were fine when i had it put in .
Profile  Offline
PostPosted: Wed Oct 15, 2014 6:39 am
kinda sounds like this
https://www.youtube.com/watch?v=1ojky3lFwGE
maybe its fine and the spool sounds louder inside with the window's up
Profile  Offline
PostPosted: Wed Oct 15, 2014 2:01 pm
For a reference, this is what my old K04 sounded like in my A4.
Profile  Offline
PostPosted: Wed Oct 15, 2014 8:29 pm
i noticed the hose from my tmic to my turbo has a very tight bend in it. would that cause anything? its litterly half the hose is blocked by the bend
Profile  Offline
PostPosted: Wed Oct 15, 2014 9:39 pm
Maybe your turbo is working harder (spinning faster) to maintain pressure past that bend. I would definitely try to fix that, your performance should improve a little bit.
Profile  Offline
PostPosted: Thu Oct 16, 2014 12:28 am
well the shop who put everything in is going to check everything
Profile  Offline
PostPosted: Mon Oct 20, 2014 7:16 pm
Mine is loud like that too. But it is in top notch condition. I figured it would be quieter like a wrx. I contribute mine being load to 3" intake and 3" exhaust
Profile  Offline
PostPosted: Tue Oct 21, 2014 1:08 am
same here. i read on other forums some tdo4's just spool crazy loud.
Profile  Offline
PostPosted: Tue Oct 21, 2014 4:10 am
Mine was barely louder than my VF-11. Definitely wouldn't say crazy loud. But its pretty subjective too.
Profile  Offline
PostPosted: Tue Dec 23, 2014 4:43 pm
Mine is a lot louder than the vf11 as well. I had concern but have been driving it for a while with no ill effects and great boost.
Rusty 1991 EJ22T - VF28 - '07 wrx TMIC - MBC - Invidia DP - Walbro 255 SOLD
1992 Legacy SS 5mt, with some neat stuff on it
Profile  Offline
PostPosted: Tue Dec 23, 2014 7:58 pm
my whistle is from the pipe they put in the silcone elbow so it wont collapse
Profile  Offline
PostPosted: Wed Dec 24, 2014 9:20 am
I miss my TD04 just because of how whistly it was through the exhaust. I loved it so much
Had more Legacy's than I know what to with...
Current: 92' SS
Profile  Offline
Who is online
Users browsing this forum: No registered users and 1 guest
Panel
Search for:
Jump to:
Dizayn Ercan Koc
