»  BC-BF Legacy Discussion »  Turbo
Custom Search
Login | Register
Post new topic Reply to topic  [ 2 posts ]
Author Message
 Post subject: EWG
PostPosted: Tue Jan 27, 2015 11:59 pm
hey guys haven't been on in a long time, but anyways finally picked up my SS donar car (totaled) to swap into my 90 LS, has the black interior and all the goodies. harness and everything is being swapped into my LS. my question is if anyone has run the grimmspeed 38mm EWG uppipe, reason im asking is because I want to know how it got tuned (if at all) with the stock ecu or if Robtune/ wrx ecu/harness merge was used I was hoping to weld or get a bracket and close off the stock wastegate and run the EWG up pipe with a dump pipe and slap on a better downpipe to go with the 3'' straight pipe I already got with the TD04 or something a little bigger.. sorry if these questions are dumb, ive been away from the forums for awhile, thanks for any input
Profile  Offline
 Post subject: Re: EWG
PostPosted: Wed Jan 28, 2015 6:36 pm
You will likely need an external boost controller of some kind. That is going to be the simplest way to handle that.
1997 Impreza OBS
Profile  Offline
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
Dizayn Ercan Koc
