underhood FCD
Posted: Mon Feb 02, 2015 11:06 pm
by turbo970
i got a fcd from cj and been searching for what wires to tap into to install the fcd. does any one have the wire diagram for the MAP sensor or can take a pic of which wires to tap into
Re: underhood FCD
Posted: Tue Feb 03, 2015 1:43 am
by cj91legss
Re: underhood FCD
Posted: Wed Feb 11, 2015 5:34 pm
by cj91legss
+5 is White
Ground is Red
Signal wire is Black
+12v comes from the Yellow/Red wire at the brown plug of the pressure exchange solenoid
I had to dig out my old car file from the filing cabinet. Had lots of other cool papers in there too.
Re: underhood FCD
Posted: Wed Feb 11, 2015 9:38 pm
by turbo970
Thanks cj that helps alot
Re: underhood FCD
Posted: Wed Feb 11, 2015 11:33 pm
by cj91legss
No problem man. I really thought the directions were in there. I apologize.
Re: underhood FCD
Posted: Sat Feb 21, 2015 3:24 am
by turbo970
all hooked up and runs fine thanks again cj
Re: underhood FCD
by cj91legss
Awesome!!!!!! You get your 14lbs?
Re: underhood FCD
Posted: Sat Feb 21, 2015 4:01 am
by turbo970
i turned it down to 12 so i can keep track of my afr's but i'll bump it back up in a day or two
Re: underhood FCD
Posted: Sat Feb 21, 2015 4:10 am
by cj91legss
Sweet.
