Boost leak??
Posted: Mon May 25, 2015 4:39 am
Hey guys, I'm a noob to this forum, so please be patient. I've just done a 20g swap with a 550 rob tune and a 20g Ecu, the whole thing. And it seems that I have a boost leak since it won't spool up past 14-15psi before it starts hesitate and buck, and once or twice now backfire. I turned the boost down to about 12 now, runs good but still every once and awhile will still hesitate and back fire. No CEL no nothing. Just changed plugs today with one step colder NGKs. I've already presure checked the whole system(FMIC) and held to mid 20s psi without so much as a hiss or leak. So I'm kinda stuck...
My buddy says it could be the factory BPV or waste gate actuator. He has the same set up with his wagon, and hits 18psi all day long.
Is there any other things I could check??
Btw I have no AFR gauge installed, but have clean yellow tops, and walbro pump, so I THINK it's not a fuel prob....but I don't know....... Frustration is starting to take over.
Any help or direction would be awesome, thanks.
