Easiest way to have 20 psi in an EJ22T?
Posted: Thu Aug 20, 2015 3:17 am
by crbastow
I have an EJ22T in my bug and I was wondering what would be the easiest way to get 20 psi? I understand that the ECU will not like any more than 10 psi and so, what would be the best ecu to use and what need I in order to do this. Thanks in advance.
Re: Easiest way to have 20 psi in an EJ22T?
Posted: Thu Aug 20, 2015 4:55 am
by jamal
I didn't really ever keep up on what guys were doing to tune these cars. I think maybe link or vipec make something that will work? Otherwise I would probably buy an AEM EMS4 and build an adapter harness. They're pretty resonably priced.
Then you would need;
Bigger turbo (at least a vf34)
bigger injectors
bigger intercooler
downpipe
fuel pump
boost control solenoid
good tune
Well, if you don't want to blow up the engine anyway.
Posted: Tue Aug 25, 2015 12:23 am
by TurnNburn
And a different MAF with higher resolution and top end, or tune to MAP if your badass
Posted: Tue Aug 25, 2015 1:05 am
by mike-tracy
Put the smallest turbo you can find in there. Then you probably won't break anything.
Posted: Tue Aug 25, 2015 3:28 pm
by cj91legss
22t, 20h dohc heads, 440 injectors, stock ecu, vf39, fcd.
I ran 20lbs on that setup. It did fine for me, but all cars are different. It was "better" than a 2.5l wrx.
Even with the TD04, and those mods the car was fun. I did go thru a few fuel cut defenders tho.
Posted: Thu Sep 03, 2015 1:01 pm
by crbastow
Well, after having talked to a guy with Megasquirt on his RX-7,
I plan on:
MegaSquirt PNP
MAF delete
Phenolic spacers
air/water intercooler
turbo upgrade (VF-39)
440 injectors
Already have a short 3" intake pipe, header and a short 3" exhaust.
This goes in my Super Beetle which stock is 1918 lbs and, I have stripped my interior.
Posted: Thu Sep 03, 2015 2:56 pm
by Alphius
Go for the STI yellowtop sidefeed 550cc injectors in EJ22 N/A rails. The 440s won't be enough fuel for your goals.
Posted: Thu Sep 03, 2015 5:36 pm
To clarify, you need the 92-94 non-turbo EJ22 n/a rails.
Posted: Fri Sep 04, 2015 1:51 am
by cj91legss
We'd love to see progress pics of this too.
Posted: Sat Sep 19, 2015 8:48 pm
by jessman1942
yeah man your not just talking about it are ya ?
