legacycentral bbs
https://bbs.legacycentral.org/
https://bbs.legacycentral.org/viewtopic.php?f=20&t=40847
Page 129 of 130
Author:  Legacy777 [ Mon Nov 13, 2017 3:28 am ]
Post subject:  Re: What did you do to your Subie today?
Finally got around to replacing the passenger side oh shit handle. Thanks again Nick!
Author:  kimokalihi [ Fri Nov 17, 2017 8:50 am ]
I miss this place. Been meaning to put up items for sale lately. Maybe the whole legacy. I go back and forth a lot on that.
Author:  dankberries [ Fri Dec 01, 2017 4:17 am ]
Completed the break-in procedure on my recent motor rebuild of my Impreza today. Excited, happy, and accomplished. Much work to do on the build journals, soon to come​....
Author:  dankberries [ Tue Dec 26, 2017 5:09 pm ]
Finished milling these 25D heads to except Kelford 282 Cam's.
Mini Mill CNC Video
Also had something strange going on with my 1997 OBS. Had negative degree temps the other morning and my speedo started​ going crazy. I'm assuming the issue is related to the cold temps freezing up things.
Crazy Speedo Video
Author:  dankberries [ Mon Jan 01, 2018 1:06 am ]
Went to the junk yard this morning to look for a legacy turbo badge and came out with a 22t short block. The badge was missing from the car unfortunately, but I have another closed deck short block for my collection.
Author:  dankberries [ Sat Feb 10, 2018 5:07 am ]
Got to use my new wiseco piston ring compressor. I have to say it is totally worth the money and makes installation extremely easy.
Author:  dankberries [ Fri Feb 23, 2018 9:01 pm ]
The heater in my 1997 Impreza OBS had been very noisy and didn't blow very well since I purchased it in October. Then the other day the fan power​ level control stopped​ working​ except in the high position.
I diagnosed the blower motor as being a worn out bearing and the fan control as being a failing resistor.
Installed a new blower motor resistor and got the fan control working again. Little tricky getting to it behind the glove box.
When I went to replace the blower motor I discovered a mouse village inside. It was no wonder why the air flow seemed so weak. Absolutely disgusting cleaning all that shit out and not the first car I've seen that happen to.
Resistor:
Author:  dankberries [ Thu Mar 08, 2018 4:54 pm ]
Been working on my GF's car the last couple days, what started as just a leaky rear main seal repair turned into a complete rebuild.
Basically whoever put there hands on this motor before me had no idea what the hell they were doing and in turn killed the motor.
Author:  mike-tracy [ Fri Mar 09, 2018 7:42 pm ]
Obviously from the "bigger the blob, the better the job" school of thought. That sucks
Author:  just-rust [ Sat Apr 07, 2018 11:45 pm ]
For my first projects, I put in a different boost gauge and swapped on some summer tread on the new, rust free addition to my driveway. Many thanks Mike. This car is a beast!
Author:  aredub2 [ Sat Jun 09, 2018 2:52 am ]
Pulled the awd parts wagon out of the bushes, pressure washed and started tearing down. Got the engine and transmission out. Going to be swapping drivetrain over to fwd sedan.
Author:  just-rust [ Sat Jun 09, 2018 3:17 am ]
Added a new row of Hella lights. Went a size bigger this time. Decided to add vinyl to the back of my rally armor flaps to give a different look and match the car up a bit more. I just did the back side of the flaps. I want to see how it holds up. Getting enough car wrap to do all four would be cheap and an easy way to customize them. Lots of different textures and colors to choose from. metrorestyling.com has a ton if anybody is interested.
UPDATE: Sooo... after banging back roads for most of the morning, I can definitely say that vinyl on mud flaps is a stupid idea. lol They are pretty torn up.
Author:  greg donovan [ Wed Jun 13, 2018 5:24 am ]
Tried to replace front brake pads. Turns out I have siezed caliper piston. Need to order a new one or get some used dual piston ones.
Author:  allnines' [ Tue Jun 19, 2018 11:43 am ]
Found a home for my '91-in Vermont-the end of the line for me-no longer an owner of the best generation of legacies! Just a fan now :(
Author:  originalcyn [ Tue Jun 19, 2018 5:50 pm ]
aww. <3
Author:  aredub2 [ Mon Jun 25, 2018 12:57 am ]
Got the tank and the rear end swapped.
Sent from my SM-G925T using Tapatalk
Author:  aredub2 [ Mon Jul 02, 2018 4:39 am ]
On the road again.
Author:  aredub2 [ Wed Jul 11, 2018 4:53 am ]
Finally got to drive today. Image
Author:  Legacy777 [ Thu Jul 12, 2018 5:16 pm ]
Woohoo! :)
Author:  beatersubi [ Sat Jul 21, 2018 10:54 pm ]
Not for my car but, added a vf38-style flange to a 3" Invidia bellmouth DP.
ImageIMG_20180721_115036610
ImageIMG_20180721_115009399
Author:  beatersubi [ Mon Jul 23, 2018 4:36 am ]
Finally found some time to work on my own garbage today.
Anyone who knows me knows what a wordsmith I'm not, and since a picture is worth a thousand words, I'll let them do the talking:
Bonus swag:
Considering my car isn't worthy of it's own build thread, stay tuned here for more.
Author:  mike-tracy [ Mon Jul 23, 2018 6:39 pm ]
You finally hooking up the AWIC? ;)
Author:  Scruff_ [ Mon Jul 23, 2018 6:47 pm ]
YESTERDAY
I did an oil change/transmission oil change/differential oil change, raised my coilovers (a bit in the front, a lot in the rear), AND took the failing tint off the front two windows. I belong to a local car club that has lifts/wash bays/oil disposal, so it makes everything an absolute breeze!
I'll have to post pictures after my first autocross on Sunday. Pretty excited for it.
Author:  JimBos Legacy [ Mon Jul 23, 2018 9:23 pm ]
Just trying to find a new turbo for her :/
Author:  beatersubi [ Wed Jul 25, 2018 2:23 am ]
Working on it.
Scruff_ wrote:
YESTERDAY
The lift and oil change are definitely worth it. What kind of turbo are you looking for?
Page 129 of 130 All times are UTC [ DST ]
http://www.phpbb.com/
