Mike-Tracy's New 92 SS
dankberries
Re: Mike-Tracy's New 92 SS
Post by dankberries » Thu Nov 08, 2018 10:17 pm
mike-tracy wrote:Question for those who have done a COP swap, do you have to plug anything in where the ignitor used to go?
No. At this point you have eliminated any need for the ignitor.
It's as simple as 4 signal wires to the ECU , one from each coil, ground each coil( I use the coil pack mounting bolt, ground wire from plug to an eyelet matching the diameter of bolt), and a power source for each coil( use the original coil pack power wire, split 4 ways to each coil)
Quadruple check your signal wires are in the correct orientation. Double check your coil grounds. Check you've got power to each coil.
93 impreza rally muffin
89 Nissan 240sx sr20
90 Nissan 240sx 2jz
Post by cj91legss » Thu Nov 08, 2018 11:34 pm
^ I'll be doing that as soon as I get back in town and get some solid time with it.
For the most part your inatructions above are what we did.
Post by mike-tracy » Sun Apr 14, 2019 3:32 am
The problem ended up being a bad starter (cranked just a little too slow for combustion), and a plug that was left unplugged after tracing the wiring.
She runs!
Josh Colombo wrote:
Mon Jan 14, 2002 10:23 am
Wait....I'm confused now.
Post by SILINC3R » Wed Apr 17, 2019 7:14 am
Find me another red SS lol. I e been pulling out parts to sell and it’s making me miss the life.
Post by mike-tracy » Tue May 14, 2019 5:25 am
originalcyn
Post by originalcyn » Tue May 14, 2019 5:34 pm
It's beautiful.
Kijan
1993 Legacy LS | PBM 227
Post by Legacy777 » Tue May 14, 2019 6:42 pm
Nice!
So what does the "twin scroll" exhaust consist of?
Are you using a twin scroll turbo?
1997 Impreza OBS
Post by mike-tracy » Tue May 14, 2019 7:43 pm
I'm using a 4th gen JDM legacy GT setup, which consists of the twinscroll exhaust manifold, the twinscroll td04-19t turbo, and the twinscroll oil pan (same pan as 2004+ usdm STI uses) and it's specific dipstick. I purchased a legacy twinscroll down pipe flange and had that welded on to a normal down pipe.
There are 2 different flange styles for factory twinscroll on the EJ engines, legacy and STI. I didn't have that knowledge when I got this one, and was hoping to swap in a larger VF36/37 STI twinscroll turbo. But no bueno, parts aren't even close to fitting.
Post by mike-tracy » Tue May 14, 2019 7:48 pm
That setup makes 276hp at 14.7 psi on the ej20x it came from. I'm hoping for at least 300chp at 18+ psi, with no appreciable lag.
Post by Legacy777 » Tue May 14, 2019 7:55 pm
Very cool!
Thanks for sharing the details.
1997 Impreza OBS
Post by mike-tracy » Mon May 20, 2019 7:42 pm
Got the sunroof working properly by reflowing the solder in the blue controller box, and lubricating the tracks. I also had the heater fan only working on speeds 1-3, turns out the nearby single fat black/yellow wire with a blue plug is what powers the fan on full blast, and that needed to be plugged in to a same color plug next to the steering column.
So far I've had almost 100% plug compatibility between my 92 SS and the 93 TW dash harness I put in. The only exceptions so far have been the auto trans and tcu plugs and the airbag wiring, as expected. I suspect the auto trans plugs would have worked if my car was auto.
Post by mike-tracy » Tue May 28, 2019 1:37 am
I spent some quality time working on the SS this long weekend. I focused on the interior. Happy to say its nearly done :D
Post by mike-tracy » Tue May 28, 2019 1:39 am
I also put 212 miles on her since the rebuild. Other than leaking valve covers and a cold start issue, she is running great!
Post by cj91legss » Tue May 28, 2019 2:14 am
Yay!
dankberries
Post by dankberries » Tue May 28, 2019 4:38 am
Wow. Those metal scuff plates are ultra rare. I spent a few years searching and couldn't ever find any.
90 Nissan 240sx 2jz
Post by mike-tracy » Tue May 28, 2019 5:32 am
Thanks, I picked them up on ebay about 7 years back. Silenc3r still has a set, perhaps he could be convinced to sell them?
originalcyn
Post by originalcyn » Tue May 28, 2019 5:23 pm
Throwing part collectors under the bus!
Kijan
Post by mike-tracy » Tue May 28, 2019 7:49 pm
Originalcyn has 2 sets he has been sitting on for years ;)
originalcyn
Post by originalcyn » Tue May 28, 2019 10:19 pm
oh no!!
That being said. I truly wish i did. I spent my time looking for that set. I'm pretty sure most people on here did at some point.
Kijan
Post by kimokalihi » Mon Jun 03, 2019 4:47 am
Nice seats, how much you want for em?
Post by mike-tracy » Mon Jun 03, 2019 5:12 am
$4500, comes with free car attached ;)
Post by kimokalihi » Mon Jun 03, 2019 2:04 pm
Hmm, but steep. I've already got a car.
Post by mike-tracy » Mon Jun 03, 2019 2:26 pm
Just search ver 1-6 JDM WRX or STI seats. Mine are ver 2 wrx iirc, and this is the 3rd SS I've had em in.
