»  Community »  Build Journals
#Joe's 93 RHD Legacy Wagon Build
Custom Search
Login | Register
Post new topic Reply to topic  [ 447 posts ]  Go to page Previous  1 ... 14, 15, 16, 17, 18
Author Message
 Post subject: Re: Joe's 93 RHD Legacy Wagon Build
PostPosted: Mon Dec 31, 2018 8:02 pm
Rad! I’m in Virginia, just outside of DC. Where you headed?
Profile  Offline
PostPosted: Wed Jan 02, 2019 6:45 pm
One thing to note is that if you use a 90 degree silicone on the inlet side of the turbo make sure it's beefy and/or rated for vacuum. Others have reported the silicone 90's collapsing under hard acceleration when the turbo is drawing in a lot of air.
1997 Impreza OBS
Profile  Offline
PostPosted: Wed Jan 02, 2019 10:02 pm
good note.
ive found the stuff from siliconeintakes.com is pretty beefy and i havent had an issue with their stuff yet
Kris
'91 Mica White SS - R.I.P.
'91 Black SS - SOLD
Profile  Offline
PostPosted: Wed Jan 02, 2019 10:04 pm
dang thats a little too far north, ill be going from orlando to north carolina
Kris
'91 Black SS - SOLD
Profile  Offline
PostPosted: Wed Jan 02, 2019 10:54 pm
Ah man. That is a nice drive though. Are you stopping anywhere in particular along the way?
Profile  Offline
PostPosted: Sun Jan 06, 2019 8:28 am
Ordered another silicone 90* and ten feet of 3.5mm vacuum hose. Thanks to everyone who explained to me ten times that I also need a section of pipe to go between things!
Profile  Offline
PostPosted: Tue Jan 08, 2019 8:03 am
visiting friends in orlando, then a buddy in atlanta, then my cousin in nc!
Kris
'91 Black SS - SOLD
Profile  Offline
PostPosted: Tue Jan 08, 2019 10:32 pm
Oh nice! HOTLanta!
Profile  Offline
PostPosted: Wed Jan 09, 2019 6:07 pm
HOTlanta for sure haha!
sorry i havent got you pictures of my intake setup yet. did you get it all figured out?
Kris
'91 Black SS - SOLD
Profile  Offline
PostPosted: Fri Jan 11, 2019 5:19 am
Hahahahaha, I honestly haven't been there since 2000, but I imagine its the same.
Its all good. I have all the information, now I just need to make it happen. I did get some 3.5mm vacuum hose today though, so thats a good start.
I should've gotten black.
Profile  Offline
PostPosted: Sun Jan 13, 2019 6:01 pm
Alright, went to the garage today for a couple minutes and I put the new silicone 90 on the turbo. The intake manifold smooshes the 90 a bit, I envision that will be a problem, yes?
Imgur isn't working, so this is where photos would be.
Profile  Offline
PostPosted: Sun Jan 13, 2019 6:24 pm
Here are the photos:
Profile  Offline
PostPosted: Sun Jan 13, 2019 11:55 pm
see if you can trim more off of the turbo side of the elbow. to make it more extreme of an angle if that makes sense.
Kris
'91 Black SS - SOLD
Profile  Offline
PostPosted: Sun Jan 13, 2019 11:59 pm
Looking at the 90 I feel like I could cut over an inch off it and still have room for clamp
Profile  Offline
PostPosted: Mon Jan 14, 2019 3:14 pm
I had the same problem with some plumbing hose that I used for my 90 degree elbow. I just bought a 90 degree silicon hose that’s made for turbos online line for like $5. You have to shave it really close to make it fit perfect.
And sorry for the Snapchat filters these are the only pictures I have :/. ImageImage
JimBo
1992 JDM Subaru Legacy GT wagon
Profile  Offline
PostPosted: Mon Jan 14, 2019 7:10 pm
yep i owuld just trim a little at a time and see how it fits every time. i find when i do silicone cutting i always cut too big first and fuck it up haha
Kris
'91 Black SS - SOLD
Profile  Offline
PostPosted: Fri Jan 18, 2019 8:13 pm
Ok, I trimmed one of the legs about as far as I could It definitely helped a bit, but the intake manifold still crushes it maybe 15%. If I rotate the 90 clockwise a little it helps, but it of course turns the 90 the wrong direction. I used a piece of PVC to test fit.
Thoughts on all of this?
Profile  Offline
PostPosted: Mon Jan 21, 2019 1:22 am
looks pretty tall and looking from the front it looks to be "leaning back" a bit. how is the hood clearance? the hard plastic will make it easy to weld in your ports.
Kris
'91 Black SS - SOLD
Profile  Offline
PostPosted: Mon Jan 21, 2019 1:32 am
The hood won’t close because I used a turbo radiator, so I’m not too worried about the hood clearance quite yet. I should probably just take the turbo to a friend and have them weld a 90 on. Shouldn’t I?*
Edit * - Are all cast elbows the same for the most part? This one is a super tight radius 2.5"
https://www.amazon.com/Vibrant-Performa ... 1FX3ECJ1F7
Profile  Offline
PostPosted: Mon Jan 21, 2019 9:23 pm
i think you should be good with that cast elbow, if you are going to find someone to weld cast aluminum you might as well have them put on a little extension just to make sure you have enough material to clamp to.
if i was in your position, id go this route. i dont know if that should make you feel better hahaha
Kris
'91 Black SS - SOLD
Profile  Offline
PostPosted: Mon Jan 21, 2019 9:25 pm
if you wanted to stick with the silicone 90, id say you could cut a bit off the vertical portion to suck the hard 90 down to more tolerable levels.
im leaving that statement open for all to tear apart hahaha
Kris
'91 Black SS - SOLD
Profile  Offline
PostPosted: Tue Mar 12, 2019 3:15 am
Hahahahah
Also, received these today. Map sensor etc. These should be the last of the turbo specific sensors I need.
Thanks, Isaac!
Profile  Offline
Who is online
Users browsing this forum: No registered users and 2 guests
Panel
Search for:
Jump to:
 cron
Dizayn Ercan Koc
