Zach's Legacy FrankenSTIn TW
Re: Zach's TW of Doom...(vid @ last page!)
You need matching cams....I don't know what the difference though between the FF & HF cams are though....
Post by SubaruNation »
i replied to you in the engine thread, have matching intake and exhaust cams. although as pairs they are different, one set being 04 wrx and one being 05 wrx. should be fine as structurally and visually they were the same.
Ok, good to hear.
Does anyone remember how the breather system ties together?
All the block portions, how are the hoses mapped?
That's one of the last things i need!
So green = Breather hoses + pcv,
blue = lines from blowoff valve, map line and that other line that i dont know what it is.
does this look ok?
Some updated pics and stuff,
Headgaskets.... haha!
Out with the Gold, in with the new
Some magic
Currently im getting jolting at about 3100rpms for some reason under full throttle... anyone have any ideas?
We are thinking it's something with the tune.. but other than that car is runnin great!
Ideas i've encountered include low compression on a cylinder... but that's not the case.
Turbo going bad wouldn't make sense if i have sweet-awesome boost above 3500..
Tune.,maybe
Mechanic/engine builder guy possibly put the timing belt in off a tooth? would that happen and cause these symptoms? or maybe the crank was off a degree or something?
it's weird because i was able to fly with no problems to 6-7-8k rpms this past summer.
Anybody who has had their car tuned care to chime in? Josh :)
jolting occurs under full throttle in gears 2, 3, 4. ..
I think one tooth off can cause about 25% loss in performance so it would be noticeable.
well if that is accurate then my timing is fine.. pcv restriction?
hmmmmmmmmmmm!!!!!
Shudder fixed!
Tuner magic at work
Second gear exploded, new transmission in. I'll post gear pics when i crack the casing.
Thanks a few of my friends and a local transmission find, car's all set!
Here's some damage shots after we cracked it,
Enjoy!
Only thing that is bad / if bad - is the front diff was welded by the previous owner so turning is kind of difficult and im 50/50 all the time.
Decided to get Lasik eye surgery...
Re: Zach's Legacy FrankenSTIn TW
Supposed to be my dynomap but isn't showing up for some reason..
So for an update on my build, I just found oil in my coolant again.
I will be pulling the motor and re doing the wiring (hopefully I can get hold of brydon), also while i have it pulled I will be
Doing new injectors and we will see what else. I'm open to recommendations, also I would love to know the best head gasket to use as I have a 22b one in here now and I guess that didnt work. Also what are recommendations for shaving the block if it is warped ?
Zach,
I fixed your image.
Are you running the stock head bolts or ARP studs?
Josh always knows the magic!
I am using what I imagine are the normal head studs.
I need to know what the most solid head gasket to get is, and while I am in there internals that will let me safely turn up the boost to eighteen .
Any ideas?
smh0101
Post by smh0101 »
Hey Zach make sure you just run the stock headgasket for the block... Ie: ej22t block = ej22t headgasket. The hg bore MUST equal the cylinder bore.
As for internals... Just do It right and be done with it... Eagles and Wisecos FTW
smh0101
Post by smh0101 »
Oh and just so you know.... Dave never took the cams out. I asked
smh0101
Post by smh0101 »
Oh and by stock headgasket I don't mean a felpro or some other brand... OEM Subaru
Spencer call me lol, you are elusive sir. I would love your opinion on this.
Also thinking i should work on this wiring while im at it... :yuck:
So just get OEM 22b headgaskets? that's what I did before, also should i get new head studs?
smh0101
Post by smh0101 »
Is your block from a 22b? I dont think so =) lol
So use the graphitey HG for a 94 Legacy Turbo FROM Subaru.
Has the engine overheated? If so how many times? How bad? If its over heated pretty badly then I would replace the head bolts. OEM ones, NOT ARP headstuds.
Please tell me the last time you did the headgaskets you looked up the proper torque sequence?
If you have stock head bolts, they are bolts, not studs.
Based on my experience with my previous motor, I would highly suggest having both the heads and the deck resurfaced. Using the stock Subaru headgasket should be fine, that's what I went back with. However, I would suggest running ARP studs for the heads. They will provide better and more even torquing, which should stand up to higher boost.
Ok,
The WRX internals are rated to 18lbs of boost correct?
If I pick these up, that seems excessive considering I already warp transmissions with my tune.
Hoff can you post which ones I specifically need?
I need to email Brydon also,
Skipping internals,
Thx anyway smh,
Was told today by theshop doing my HG's that because of the differences between the heads and the block surface that i would continue to have problems with theHG's. Malarkey : http://bbs.legacycentral.org/viewtopic.php?t=27136
Anyone else have similar experiences? I know I've got a "hybrid" or whatever and they might be saying this because they arent comfortable doing the work...etc.
