94 Legacy RS Turbo Wagon (fixed pics/updates!)
Yes, they took 8 weeks to put the bottom end of this motor together, didnt reassemble Tims heads, left the oil pick up tube loose, blasted holes in the oil pan, and left blast media all over the engine.
Anyways, I got the whole motor assembled now. Just waiting on the new oil pan to get in so I can tap the oil return line into it, and the new tensioner to come in. Other than that she should be running by turkey day.
Couldnt get the PP6 engine management, so we will have to run on stock boost pressure for a while, until another one can be found. We will still dyno it though for shits and giggles. Maybe run a little more boost when it gets broken in, like around 10 PSi. I figure the base map with the larger injectors (STi) should handle it OK.
Any thoughts on this?
98 LGT wagon auto
PNP heads, wrx 5 spd conversion, sti struts, whiteline suspension, 4/2 pots, lots more
05 impreza wgn stock
On the base Turbo ECU you cant run bigger than 440cc injectors.
So would 10 PSI on a TD04 be ok after break in? Tim will eventually get it tuned, and I emagine upgrade to a larger turbo and injectors, but for now would rather have an ample amount of boost while still being safe on a stock map.smh0101 wrote:On the base Turbo ECU you cant run bigger than 440cc injectors.
Pics coming soon BTW, and we should be installing it Wed, and hopefully by Fri have it running.
The stock T-belt tensioner for the EJ22T does work with the DOHC heads BTW, perfectly in fact. FYI
98 LGT wagon auto
Oh hell yea, I'm running 15lbs on a VF10 and an '06 TMIC jsut fine.iluvdrt wrote:So would 10 PSI on a TD04 be ok after break in? Tim will eventually get it tuned, and I emagine upgrade to a larger turbo and injectors, but for now would rather have an ample amount of boost while still being safe on a stock map.smh0101 wrote:On the base Turbo ECU you cant run bigger than 440cc injectors.
A td04 is not much bigger than a vf11, and about the same size as a vf10.
Cool, thats good to know.
We have the engine in the car now. Just need to figure out a few things.
We are having trouble getting the 06 TMIC to fit. The 90 inlet hose on the IC is about 2" behind the outlet on the turbo. Maybe it isnt sitting low enough in the engine bay.
I have no idea where all the vacume hoses go. Which hoses on the stock boost control need to be hooked up in order to run a MBC? Which hoses hook into the intake (IAC, and PCV what else). I think think the bottom hose on the boost control also goes into the intake tube.
Do we need the charcoal canister? Right now it is hooked up.
Still need to figure how to get coolant to and from the Turbo. We didnt drill the head to have a coolant return. I might run the return into the radiator and supply it from the heater hose.
Pics soon.
Pics soon.
98 LGT wagon auto
PICS
98 LGT wagon auto
Motor is in.
I got sweet vacume line diagram from the FSM and got the canister and all solinoids hoooked up. 07 WRX TMIC is sitting in the garage, we are waiting on the ebay Y pipe kit to come in.
Turbo coolant lines are still an issue which I will resolve tommorow.
Turbo inlet will be made tommorow, probably from a Radiator hose for the 90 and some tubing with fittings braized in for the IAC, PCV, Purge, and whatever else needs to go there.
I should be able to start it up tommorow.....damn I am nervous. I always get that way when I am done with engine work. My hands shake thinking about it LOL.
98 LGT wagon auto
The IC is not mounted up to the throttle body note the plastic bag..it was raining and I was trying to see where to mount the coolant tank and other things. Its just sitting in place. It fits in there just fine and snug.94SS_Canada wrote:From those pics, it looks like you have clearance issues.
The valve covers are close to the firewall though, should be a lot of fun changing plugs lol.
98 LGT wagon auto
OK so the motor is in and it wont start.
initially I had timed the motor to the wrong timing mark on the crank pulley the little triangle (it is fixed now I used the mark on the crank sensor trigger), but everything turned over fine by hand initially so I should not have any probs from that originally being wrong. Now it is right.
Got spark
fuel pressure is 38 cranking
MAF is kinda rigged up to IC which is rigged up to the throttle body, but the connections are solid, and are only temp
All the fuel injectors are wired up right according to schematics on mitchell on demand
everything is plugged in and connectors have been double checked.
I do have code 45 boost sensor, but I dont think that would keep it from fireing. The car came with a fuel cut defender which is wired in to the sensor, and apperantly worked prior to the rebuild.
I have no idea why this thing isnt starting. Ill do a compression check tommorow to make sure everything is OK.
Any other thoughts would be greatly appreciated. I have a t-shoot link in the engine forum BTW. Thanks
Got spark
98 LGT wagon auto
ITS ALIVE!!!11!!
Fixed up the intake plumbing a little and BAM shes running. Healthy I might add. She has a little stumble if you stab the gas, but I think with a little TPS adj and some tweaking shell be good. Finished product coming soon!
Struts are next.
Struts are next.
98 LGT wagon auto
He shouldnt know how quick it is for at least 500 miles on her because the shortblock was rebuilt. It could mean bad things if he does.... After that... you good!
Exactly. After 500 miles I am also changing the oil again with Mobile 1. Right now is has regular Castrol 10-30. We will also take extra precaussions and run low boost as well. About 5-7 PSI.smh0101 wrote:He shouldnt know how quick it is for at least 500 miles on her because the shortblock was rebuilt. It could mean bad things if he does.... After that... you good!
After breakin well crank it up to about 12 and set until the PP6 is installed.
Tim is also working on gettin a rotated set up forthe turbo to make the intake plumbing a little easier.
98 LGT wagon auto
What did you do to prepare the alluminum for paint and what did you paint it with. It does look like you did a great job on the painting but its probably all going to flake off like mine has
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
Its not paint its plasticoat, baked at 350.
Well water is in the oil. We pulled the pan and it is dripping from the big coolant pipe at the fron of the motor (on the inside). Apperantly the machine shop didnt put any RTV between the block halves.
Pics soon.
Pics soon.
98 LGT wagon auto
from the coolant pipe.
98 LGT wagon auto
If I'm not mistaken, there is an O-ring there. So the presence, or lack of, RTV should not cause a coolant leak in that spot.
I'd check carefully and make sure they didn't assemble the engine with old o-rings (or no o-rings!!)
I leave for Iraq in 3 weeks so Tim will have to take it up with the shop. We dont have the time to split the block (and I have never done that which is why we paid them to do it).
I am so pissed.
I am so pissed.
98 LGT wagon auto
