My sleeper LSS named "Trixie" (56k Beware!)
Picked up my 5 speed tranny and swap parts today from Frank only after taking a wrong turn and going 40 miles out of my way... Looks like I should have taken my wife with me. She's better at keeping me on course than some expensive nav unit any day!!!
Borrowed my brother-in-law's '91 Legacy wagon to bring everything back which only has a mere 268,xxx miles on it. My '85 Chevy truck likely would have died along the way (burning oil badly inside the driver side of the motor).
Now I just have to get the dead 4EAT out of the car and get the new goodies installed! Once that's finished, I can run around the neighborhood raising hell w/o an exhaust connected to the downpipe!!!!!!
Jason
No exhaust gets annoying! We have been tinkering with ours with just a downpipe and it made it very difficult to hear anything that is going on engine/transmission wise. I finally plumbed a 2.5" exhaust to the axle back so we can hear what the motor is trying to do. The turbo sure does sound sweet like that though!
[b][color=white]-Ryan-[/color][/b]
"We live for a good time, not for a long time." -Colin Mcrae
[url=http://wrxmodders.com/forums/viewtopic.php?t=15103]Project RallyX: 1991 Turbo Legacy[/url]
Oh hell yeah it does! All you hear is turbo out the downpipe. The farthest the car will drive is 2 blocks over to Monro Brakes & Muffler where the assistant manager is going to take care of fitting up my A'PEXi N1 exhaust. It's originally for a WRX, then my buddy who picked it up used had the length changed to fit his 2.5RS. Now it's going on my car!
Jason
Ordered a Kartboy poly rear shifter stay bushing Monday evening to replace the non-existent one I don't have... FAIL! So now my shifter is using only Kartboy poly products to firm it up. I needed to steal a cam position sensor from my spare EJ22T motor because something torn into the factory one. I made it through all the forward gears and reverse without a problem. The U/P, turbo and D/P get torn back off to be heat wrapped. The turbo is getting swapped in place of one that I gasket matched and smoothed the exhaust inlet of for quicker spool up.
Pictures will be coming in the next day or so as I get the spare time. Should be able to take a test drive by this weekend if all goes as planned (which it NEVER does!!!). Sunday it gets shipped off to my local Monro Muffler shop for a freebie 4 wheel alignment and downpipe back exhaust install. Supplying parts to a shop each day has it's benifits!
Jason
Well after many delays... She will be getting full 3" exhaust installed on Wednesday. It was supposed to be today buy the 3" flex pipe I ordered from a shop on KS Tuesday morning before work didn't arrive yet. It's coming USPS Priority (2-3 days) and should have been here by Friday at the latest. I received a notification that it was shipped on Tuesday as well. The tracking info shows it is enroute to me but it should have been here by now.
While it's getting the exhaust installed it will receive a state inspection as well. This will all be done just in time to attend my buddy's wedding (Strat over on DI) in Wellsboro (home of the STPR rally event) on Saturday. There will be many Subarus there as he and his future wife both own Subies and they have a RallyX project vehicle together too.
Once all the bugs are worked out I will be ordering up the AEM Fuel/Ignition controller to handle all the tuning aspects on the car. Can't beat it for $400 and also the fact that a member is using it on his car currently with a full install write up!
Jason
I need to know who this isdropdfocus wrote: Once all the bugs are worked out I will be ordering up the AEM Fuel/Ignition controller to handle all the tuning aspects on the car. Can't beat it for $400 and also the fact that a member is using it on his car currently with a full install write up!
The SLODRIVE '92 SS Build (warning: UGLY pics!)
http://bbs.legacycentral.org/viewtopic.php?t=38549
Page 3 is where he starts the info on the AEM F/IC.
Jason
Forgot to post this on Wednesday at 3:30am (EST):
* Hooked up my boost gauge which was a pain in the a$$ getting a coiled up plastic hose to play nice when snaking it in small tight spaces
* Sealed up the TurboXS BPV which I believe to have been leaking past the rubber seal the '06-'07 TMIC uses vs. a gasket
* Threw in some interior plastic trim pieces & the overhead lights to make it look a bit more presentable
* Prepped the radio to allow me some music to sooth my beast
* Hooked up the speedo cable (long story, don't ask...)
* And lastly used one of the head light restoration kits we sell at work. These kits are THE BEST on the market for less than $20!!!!
Now tomorrow a bunch of us will be heading up to Wellsboro, PA for a DirtyImpreza.com wedding. Spencer and Tasha are tying the knot. It's gonna be freakin' sweet!!!!!
As of this evening I just spent 5 more hours in my garage working on my baby.Well the car is off to get the 3" exhaust installed and get a state inspection done.
So let's see...
* Reverse lights tagged in from the 5MT wiring to the 4EAT wiring - Check
* Neutral safety switch bypassed to trick the computer into letting me start the car - Check
* Car starts up and the reverse lights turn on when placed into reverse - Check
* Bad ground on front turn signal harness taken care of - Check
* Hella Supertones installed and LOUD - Check
* All light bulbs in good working order - Check
* All fluids at a proper level - Check
* 4" of snow on the ground starting at 10pm and still more to to go - Check
* Excited as hell to have my baby on the road FINALLY!!!! - Fo Freakin' Schizzle!!!!
Jason
Trixie made her first long distance drive without any real issues. The 55-60 mile trek to Wellsboro was made at pretty much a constant 85mph especially on winding back country roads. She held up to the task like a pro at only 10lbs of boost. The only real carnage was having grease on my D/S front wheel pointed out to me. Looks like the rubber boots on the axles I rebuilt didn't like the sustained speeds I gave it. Oh well, time to pick up a new (not even chancing a reman axle) one from work this week. The lowered suspension is coming out in favor of the Skunk2 coilovers that I was going to wait on installing. The front suspension bottomed out a bit more that I'd care to like and I'm rubbing the inner front fender wells. So time to lift the car up for the winter months.
All in all it was a good outing with the car. I've got a few bugs to work out and some other stuff to take care of as well. I did notice that the custom air intake I designed likes to "sing" at higher rpms. I thought the turbo was going to let go until Rich & I figured out that it was intake noise instead. Not sure I can do much about that.
Jason
Howdy Spence!!!! Welcome to the party finally...
As for the time frame, I don't care. Do it once and do it right was my main effort through this entire build. Granted the build is not finished just yet as there is MUCH more to come... In about 2 months or so I should have some more parts swapped out in favor higher HP numbers. My end goal is still to hit 325chp on mostly "2nd hand parts".
Jason
Um yeah, like twice and it's been within this thread. So what you're really saying is that you've been stalking me on here???strat wrote:i've been a member for a bit... just don't post much.
I am using '00-'01 Impreza RS wheels (16x7) for the summer use so that I can put 225/50/16 performance tires on them and then I'm have the '02-'04 WRX wheels (16x6.5) on currently for winter use but I'd really like to find a set of the '05+ WRX split 5 spoke wheels to use for the winter. I'd run them as summer wheels but they are only 6.5" wide unlike the RS wheels.turbo_meow wrote:man i like the rims on your car man are you lowered? and if so what did you use
The car is currently lowered on Progress Sport Springs which are meant for the WRX platform. They are getting pulled off once I get the rear KYB AGX struts shortly. I have Skunk2 coilovers to be installed on the car which will allow me ground clearance during the winter months and then slam it back down for AutoX season.
Jason
Got the new suspension bolted up late last night after fighting with it. I removed shot factory struts mated with Progress 1.75" lowering springs in favor of Skunk2 coilovers (Application: WRX) on KYB AGX struts front & rear (Application: 92-94 Legacy & WRX). The front went together w/o any hassle. The rear was a whole other story unfortunately...
The threaded sleeves are meant to slide down the body of the strut tube, but there is a slight problem with that in the rear thanks to KYB's over engineering. The ID of the threaded sleeve is 51.35mm, but the OD of the AGX rear strut tube is 54mm. So it now places the sleeve on top of the tube instead of down around it. This works for right now as I wanted the car lifted up for the winter months. Problem is, I can slam the front end just fine, but there is very little adjustment down on the threaded sleeve in the rear.
I'll be sending an email off to Skunk2 to see if they can assist me with this or if I get written off and just sell the coilovers. The factory struts have a proper body diameter to work, but I have no intentions of getting rid of my AGX's any time soon!!!
BTW, I should have suspension pix up later today.
Jason
Before you sell the coilovers: Do you have any way of turning down the ID of the sleeves to fit over the strut bodies? That would probably be a more cost-effective way to get the suspension adjustability you want. A machine shop in your area could/would probably do it for a small fee.
I should've mentioned this earlier on the DI.
[quote="RJ93SS"]u fail, epicly[/quote][quote="evolutionmovement"]Don't do drugs, kids, men may not need nipples, but we look a lot funnier without them.[/quote]
Jason,dropdfocus wrote:Picked up my 5 speed tranny and swap parts today from Frank only after taking a wrong turn and going 40 miles out of my way... Looks like I should have taken my wife with me. She's better at keeping me on course than some expensive nav unit any day!!!
Whencan I expect to get paid for this tranny? I trusted you.
