Miguelones Australian Delivered RS Turbos
Re: Miguelones Australian Delivered RS Turbos
Are you still on the legacy ej20g heads?
Miguelone
Post by Miguelone »
Yup still running rocker arm heads.
If you could find some ej20k heads on the cheap, they are a worthy upgrade. Either kind revs all day!
Miguelone
Post by Miguelone »
I like the early heads. Might not make as much power but nothing can compare to that growl.
You might also have the group-a style headers that I've been casually searching for. They produce great sound. I don't doubt that your heads also contribute however.
here is a comparison: (replace USDM with "non group-a style stock headers")
Legacy777 wrote:
94Leg-c wrote:Josh, which of the two is the jdm?
JDM is on the left
http://www.main.experiencetherave.com/s ... G_0982.JPG
JDM is on the right
http://www.main.experiencetherave.com/s ... G_0989.JPG
You can see how the JDM manifold is larger and has more runner length.
