Big C's Legacy SS Build
chanley2010
Post by chanley2010 »
A little background before we get into the gritty details. I bought the 91 legacy turbo from a high school friend who beat it up pretty good. Found it barely running, sputtering poping and banging and pretty much on the verge of going to the junkyard. Was told for 400$ it was mine to take. Needless to say i speed to the bank and became the proud owner of the leggy! After towing it to a friends we through some plugs in it and wires, to fix some of the rough running but still wasnt quite right. Before this id never had a turbo car and made the mistake of filling the car with 85 fuel instead of 91. After realizing the mistake i ran the piss out of it with cleaner and octane booster till i was able to refill with 91. After reading and trial and error to figure out Inwas having a low fuel rail pressure on the passenger side. I replaced the fuel pressure regulator which made the difference between small boost and full boost.
originalcyn
Re: Big C's Legacy SS Build
Post by originalcyn »
Congrats! Can't wait to see photos.
Kijan
1993 Legacy LS | PBM 227
chanley2010
So havent been able to figure out pic and video uploading and been away working on a crank no start issue, went through the entire car from fuel to ignition to ecu to wiring come to find out the car had jumped time due to one tooth broken off on The timing pulleys. Thank goodness no bent valves or smacked pistons! Car is now running and idling strong however i began to notice hesistation from the dig so going to have to look into what maybe the cause. Pics to come
Subaru's only non-interferance turbo ej motor! As to pics, you'll have to upload your pics to Flickr or photo bucket or similar, and post the IMG links here
ScaryfatkidGT
Post by ScaryfatkidGT »
GOOD JOB! I just got one they are fun, is everything else stock?
chanley2010
Not at allmost of the caris entirely aftermarket hoping to only keep minimal stock
chanley2010
chanley2010
chanley2010
chanley2010
This is the original set up after a basic cold air was thrown on
chanley2010
Car at rocky mountain subaru fest in 2015
chanley2010
Donor engine from a 97 ouback with the ej25d dohc heads on the new turbo motor!
chanley2010
After block rebuild and heads installed with cometic head gaskets
chanley2010
Old 16g turbo vs the brand new 20g turbo!
chanley2010
After the fcd was installed on the first couple pulls after narrowing in the settings! Boost, go fast!
chanley2010
New clutch, flywheel and full exhaust for the frankenstein motor
chanley2010
The 97 heads all torn apart waiting for head gaskets to properly shim cams after
chanley2010
Sporting some wrx seats for comfort and some actual stability during the corners
chanley2010
Getting those parts ready for the hybrid motor!
chanley2010
Block after heads removed to begin the hybrid head project
chanley2010
Most recent picture of the suby since the coilovers went on and the interior was redone
chanley2010
Video of the sub after the frankenstein engine installed and bugs worked out of the tune! Love the sound:)
chanley2010
Finally got some pics up hope yall like what ive done! Lately been dealing with a hard fuel cut at 6lbs on a robtune and a limp mode on the stock ecu, not to sure the cause yet but continuously showing code 45 , the pressure exchange soleniod and pump basically, assuming thats probably the issue.. however im also seeing an abs code from the rf wheel speed sensor, any thoughts if that could actually be the issue?
chanley2010
Found this old pic from the day we picked it up and started building!
This is shaping up really nicely. Same color as my first SS I think. Congrats!
