Paynter's 1993 RHD Legacy Wagon build
turbo_gc8
Post by turbo_gc8 »
Hi! I've creeped these forums for a long time and have decided to actually make a build thread now that I have a Legacy.
My car is a JDM 1993 Legacy Wagon
When I picked it up from ten previous owner, it has been very badly assembled. For some reason the EJ20G was removed and an EJ22T long block dropped in its place. The wiring was a disaster supposedly has a Rob 550 tune. After taking the ecu out I realized it didn't and had been running 550cc injectors using the 440cx oem tune.
I ordered an ESL daughter board, installed a VF48 turbo as the original turbo was pretty noisy, installed a TBE and a FMIC.
I bought it for a beater originally but after driving it for a few months I began to fall in love with it.
I decided if I was going to do this on such a neat car, I was going to do it right. I ordered a set of Darton Dry sleeves, wiseco 99.5mm pistons, 2012+ heat treated crank, Haltech, 2200cc injectors, Borg Warner S366 turbo, and dug out a spare set of D25 heads I had around. I also picked up a V7 6 speed local from a friend and 6 puck Comp clutch.
I ordered a bunch of other parts as well but am waiting on them.
Just picked my block up from the machine shop the other day
Current:
2006 STI GT3582R 29psi on pump/meth
1993 RHD Legacy wagon S366 turbo.. number soon
1993 RHD WRX EJ205 swap
Re: Paynter's 1993 RHD Legacy Wagon build
Did you have the block sleeved?
turbo_gc8
Post by turbo_gc8 »
Yessir! Sleeved and bored to 99.5mm
Current:
turbo_gc8
Post by turbo_gc8 »
Just finished assembling the short block
Wiseco Pistons 99.5mm
Manley H-Tuff rods
King main bearings
King rod bearings
Current:
turbo_gc8
Post by turbo_gc8 »
Time Lapse of the block assembly
https://youtu.be/JqhY8eX-eTY
Current:
It's hard to tell from the pictures, but do the sleeves protrude from the deck? If so, how is that going to affect your head gasket sealing between the cylinders and the oil/water jackets?
turbo_gc8
Post by turbo_gc8 »
Legacy777 wrote:It's hard to tell from the pictures, but do the sleeves protrude from the deck? If so, how is that going to affect your head gasket sealing between the cylinders and the oil/water jackets?
The do, it's about 0.001", as per Dartons recommendation. The machine shop contacted Darton and they told them to as it seats better apparently, using JE or cometic gaskets. You can just feel the lip with a finger nail. I also double checked with Darton and then with a feeler gauge to confirm :)
Current:
turbo_gc8
Post by turbo_gc8 »
Our CNC prototype pieces we designed for rotated NA intake manifolds came in today that we will be using on this engine
Current:
Pntaste4evr99
Winestone Cowboy
Post by Pntaste4evr99 »
Those brkts are sexy
94 Winestone SS 5MT Rob 550 20g. (Pickle)
Original WA car with 460k miles and climbing
Very nice CNC brackets!
turbo_gc8 wrote:The do, it's about 0.001", as per Dartons recommendation. The machine shop contacted Darton and they told them to as it seats better apparently, using JE or cometic gaskets. You can just feel the lip with a finger nail. I also double checked with Darton and then with a feeler gauge to confirm :)
Ok, that's good to know.
I want some of those brackets...
turbo_gc8
Post by turbo_gc8 »
cj91legss wrote:I want some of those brackets...
They will be on the market soon as a kit and as parts individually
8)
Current:
turbo_gc8
Post by turbo_gc8 »
More parts arrived today
Haltech Wideband controller
Aeromotive FPR
Deatschwerks fuel rails
Deatschwerks 2200cc injectors
Comp 6 puck clutch
Current:
turbo_gc8
Post by turbo_gc8 »
Few more parts have show up. Heads are assembled now, just have to adjust lash. Just waiting on the head gaskets to get the long block assembled
AEM 5BAR MAP sensor
AEM IAT sensor
Tial 44mm EWG
GSC beehive valve spring TI retainers
GSC intake and exhaust valves
GSC valve seats and seals
Brian Crower Stage 3 cams (280/280)
New OEM 6 speed flywheel
BC coilovers I picked up local to replaced my old worn out D2 coils. These had like 1000km on them and got them at a steal
GRIMMSPEED AOS. I wanted to give it a try as I've heard mixed reviews. If I don't like it I'll just swap it with my wife's Crawford V2
Current:
turbo_gc8
Post by turbo_gc8 »
Little update today:
Started to remove everything from the bay I didn't need and clean things
Pulled the JDM 5 speed and rear diff out to make room for the 6 speed gear
Pulled the dash out so I could get the wiring harness out to strip what is no long needed and get ready to wire in the Haltech
Current:
turbo_gc8
Post by turbo_gc8 »
Been a little slow going as I'm still waiting on my damn cometic head gaskets to finished getting my engine together
In the mean time I clean the bay and removed the rest of what I wasn't going to use. I also installed the 6 speed
Also finished the bulk head harness with just the wires left that I'm going to use to wire the haltech.
I also started the engine harness, removing things I'm not using and adding things I will need that arent there
Also ordered up a couple sets of OTL coil packs for the Legacy as well as buddies 2012 GT3582R STI.
We decided to compare turbo sizes for fun
VF48 on the left, Garrett GT3582R in the center and the BW S366 that's going on my Legacy wagon on the right
Current:
turbo_gc8
Post by turbo_gc8 »
Got the engine in but it hits the hood currently so I need to fix that unfortunately
Made all my fuel lines
Mocked up the turbo to get an idea where I'm going to need to cut and ram the haltech wiring
Current:
turbo_gc8
Post by turbo_gc8 »
Haltech wiring all done and turbo is now mounted. Should have some new pictures soon just been busy with customers cars and moving into our new shop. Hopefully we will have our dyno installed in the next couple weeks which will be MUCH nicer to tune on
Current:
originalcyn
Post by originalcyn »
so pretty! Nice job.
Kijan
1993 Legacy LS | PBM 227
Pntaste4evr99
Winestone Cowboy
Where's your shop located?
