so already FMICed my Legacy turbo.. like a year ago... sold it... deal fell through... so now Im turning it into a wicked winter beater... I sold my intercooler so now im looking into buying another.... I guess I wanna try somthing different on this trip around because I have all summer to build while i drive my delsol...
A. has anyone found a kit from ebay or what have u for a GC8 impreza or a newer legacy/impreza for FMIC that can be easily modified to fit or that is a direct fit... im mainly looking for a way to FMIC using less couplers thus less room for one to pop off an for me to get out in the cold and fix it
B. has anyone found a better way to run a TD04 compressor inlet pipe better then using a WRX intake manifold and running it under as they do it the WRX
C. when I ran a cone filter my MAF did not like it one bit... anyways around this lengthen distance between maf and filter or anything like that??
so all in all Im just looking for some new ideas to try this time around as ill have the money and the time to do it...
intercooling
Re: intertooling
Re: intertooling
I'm using a 90* silicone pipe that I bought off of e-bay for $20.00 and some T-bolt clamps to make sure it's not going to leak or pop off. It's been on there for a few months and it hasn't shown any signs of melting or leaking.Gregmckenna wrote: B. has anyone found a better way to run a TD04 compressor inlet pipe better then using a WRX intake manifold and running it under as they do it the WRX
