good fmic kit
Front, Top, Air, Water.
turbo turtle21
good fmic kit
Post by turbo turtle21 »
ok ive recently just bought an tdo4 turbo and i want to put a fmic on when i put the turbo on could anyone tell me a good kit that gunna take the least work and cuttin and all that and i have a 91 legacy turbo by the way thanks
Anything you do is going to require a reasonable amount of modification and cutting. There's really no way around it...
Has anyone bought a FMIC kit for a wrx or like 94 WRX????
subytech
Post by subytech »
no 02or newer WRX kit will bolt up, I've bought 2 ebay generic pipe kits and a CXracing intercooler and still had to revise my setup 3 times and have 3 pipes welded for the set up i have now, and its still tight at the RH cyl. head.
92 Legacy Turbo, 5sp MT, Early Large CC 20G heads, Ported custom clocked td04, Cobb catted DP, Injen SS 3" exhaust, Turbosmart MBC @ 10psi, Apexi 20g intake, custom FMIC, Fidanza 11lb flywheel, stock 05 WRX clutch
subytech
Post by subytech »
the set up for the compressor outlet is a combination of high temp nylon fittings ment for marine aplication and flexible marine exhaust tubing. been using it for close to 10,000 miles of mostly freeway no problems but cheep, i should have known better than to use, tube connectors
RCKSTR
Post by RCKSTR »
I'm thinking of picking up one of the "JDM" fmic kits off from ebay. once I do so I'll post up how the fitment is.
91 leggy SS, work in progress...
04 wrx w/ jdm twinscroll and lots more... 300whp :-)
i picked up a greddy kit from a forum member a year and a half ago and it fits ok... it's for a wrx and i also had to extend some piping by my driver's side head.
impreza_GC8
Post by impreza_GC8 »
subytech wrote:Image
So is this a combination of a few kits plus custom work? Or is there a kit that is available that is close to this? I like the setup of the piping on this one.
-'97 Outback - EJ25 block/pistons/HLA heads, EJ22T crank/rods/ECU, EJ20G intake manifold/fuel rails/440cc injectors, VF8 @ 11psi. . . . Fuel cut > me
That setup in the pic above seems more "reliable" to me, I had a theory (Not proven) that the less restrictions for air flow, the better.....
Here's mine before my TD04 Install, it flows towards the passanger side first... I am eventually going to fix it some how.
subytech
Post by subytech »
A few kits that looked like they had the bends I wanted not sure if they were subaru specific i just looked at the pics and found the bends that looked good. I also had some custom welding done up near the throttle body and the turbo to get the bends just right, I like straight running pipes, not akward looking connections and kinked hoses, but then I'm OCD so they tell me :-D
Apex3
Post by Apex3 »
I've actually heard the ebay FMICs are pretty decent, it's just the fittings and junk that come with them that are crap.
brweber352
Post by brweber352 »
My FMIC is at the bottom of this link with a slight description http://bbs.legacycentral.org/viewtopic. ... art=25[url]
I would like shorter piping and a more direct route but this was a fairly easy install(if there is such a thing as a easy FMIC install). As far as lag goes, not really noticeable. My TD05 hits 0psi at about 2600 -2700rpm and 16psi at like 3300rpm with 2.5'' exhaust. With my 3'' cutout open, What lag? 0psi seems to be at like 2400-2500rpm and 16psi seems about 3100rpm, this is just me glancing back and forth between the gauges so I need to datalog this to be more accurate.[/url]
93'TLegWag171k StockBlock,TD05,HallmanMBC,530cc,Walbro255,shortram,LWpulley,DIS-2,MSDcoil,cxrFMIC,trans cooler/external filter,WRX wheels/brakes,CES w/Borla muffler,QTP elec cutout,REVchip2,KYB GR2,GroupN tops/all fr bushings,STImounts,GSD3 tires,LM-1,etc
