»  BC-BF Legacy Discussion »  Intercooling
#Direct fit AWIC kits on the way.
Custom Search
Login | Register
Post new topic Reply to topic  [ 152 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7
Author Message
 Post subject: Re: Direct fit AWIC kits on the way.
PostPosted: Mon Nov 04, 2013 8:35 am
My main concern is weather enough air will flow through the front of the bumper, which is effectively sealed off from the bottom, for the exchanger to be effective in that position. To be sure, one would need to use some sort of manometer to check pressure differentials between the area behind the front bumper and inside the front of the wheel well, ideally with any kind of vent that would be used with the exchanger in place.
Another concern would be potential damage from any debris thrown off by the tire.
93 legacy wagon L, 22T swapped (TW imitator) now with five forward speeds.
johndrivesabox wrote:
Rally, my kyboard is brok, his has nohing o do wih h liquor.
Originalcyn wrote:
Apparently everyone hates Gabe.
Profile  Offline
PostPosted: Tue Nov 05, 2013 3:01 am
Check out my AWIC exchanger thread.
viewtopic.php?f=3&t=35394
As it's been mentioned the bumper beam is your limiting factor, and it can be cut to allow for more room. I am very happy with the exchanger I had built. The only thing I'd do different is add a bleeder screw in the top left corner and anodize it black.
Here's a thread with my old exchanger setup where I didn't cut the bumper beam, and I just wasn't too happy with it.
viewtopic.php?f=3&t=23089
To get anything that will work well, you're going to have to do something with the bumper beam.
1997 Impreza OBS
Profile  Offline
Who is online
Users browsing this forum: No registered users and 1 guest
Panel
Search for:
Jump to:
 cron
Dizayn Ercan Koc
