TMIC install hardware help?
Front, Top, Air, Water.
kleinkid
Post by kleinkid » Sat May 25, 2013 3:38 am
This is available now, may help with that TMIC install.
http://www.grimmspeed.com/catalog/image ... yUyLST.jpg
Re: TMIC install hardware help?
Post by mike-tracy » Sat May 25, 2013 6:53 am
Hmm. Part number or name?
Josh Colombo wrote:
Mon Jan 14, 2002 10:23 am
Wait....I'm confused now.
kleinkid
Post by kleinkid » Sun May 26, 2013 4:43 am
Post by mike-tracy » Sun May 26, 2013 6:03 am
Seems not too bad, 99 and comes with t-bolt clamps.
Post by cj91legss » Sun May 26, 2013 4:29 pm
Wish I would have ordered that kit when setting up the girlfriend's tmic...
Post by SILINC3R » Sun May 26, 2013 5:34 pm
Anyone thinking of ordering this and giving it a shot?
kleinkid
Post by kleinkid » Mon May 27, 2013 5:36 am
I probably will use this on my '94, but that won't happen for a while. Cheaper than buying a silicone y pipe that you have to cut up to use.
devilzdriver
Post by devilzdriver » Tue May 28, 2013 2:57 pm
I have been thinking going AWIC, but i have realized.... its a PIA to set up, from what my friends have said. I assume this will make the TMIC install insanely easier then before?
Post by mike-tracy » Tue May 28, 2013 3:49 pm
^it appears so, but no-one has bought the kit to find out yet ;)
devilzdriver
Post by devilzdriver » Wed May 29, 2013 5:17 am
mike-tracy wrote:^it appears so, but no-one has bought the kit to find out yet ;)
In hawaii finding a damn 06 TMIC is tough lol....
alexandermf
Post by alexandermf » Wed May 29, 2013 7:33 am
Looks like mine kinda.. .
It did make taking the tmic on/off and apart much easier :)
robertpaige
Post by robertpaige » Wed May 29, 2013 8:15 am
Maybe i'll try it. I've got a mix of silicone tubing going on.
Had more Legacy's than I know what to with...
Current: 92' SS
devilzdriver
Post by devilzdriver » Fri May 31, 2013 6:32 pm
I just ordered the setup we shall see, i am just waiting on my TMIC.
robertpaige
Post by robertpaige » Fri May 31, 2013 9:05 pm
Hell yeah. Excited to hear the results, hopefully it fits up pretty well without any modification.
Cause if it's one thing we know how to do well with our cars, is modify everything to fit... Lol
Current: 92' SS
devilzdriver
Post by devilzdriver » Sat Jun 01, 2013 3:19 pm
robertpaige wrote:Hell yeah. Excited to hear the results, hopefully it fits up pretty well without any modification.
The guy im buying my TMIC from is slackin lol, but as soon as it gets in ill let you all know. I am in Hawaii just so you all know. lol
devilzdriver
Post by devilzdriver » Thu Jun 27, 2013 5:30 am
TMIC is at my house still waiting on that damn y pipe lol as soon as i get it ill let everyone know how it goes together.
just-rust
Post by just-rust » Tue Mar 25, 2014 2:22 am
I am going to revive this thread a bit. I decided to get this kit as it seemed to get everything moving in the right direction. However, I needed to do two things to make this work on my '07 WRX TMIC.
First, was to get a 30 degree elbow from silicone intakes (http://www.siliconeintakes.com/product_ ... 1eebe83657). This made the link from right to left side piping as they were not aligned very well. I also had to cut the elbow down. The grimmspeed connecting hose had no chance here. I also used the left side WRX TMIC metal piece as it minimized the gap that the grimmspeed metal piping created. (Shown in photo) Now it seems to be ready to install.
I am new to this and my vocab sucks so I hope this makes sense. Next will be the installation. I will report back after that has happened! Still going back and forth between leaving the 11 in or going with the TD04…
Rusty 1991 EJ22T - VF28 - '07 wrx TMIC - MBC - Invidia DP - Walbro 255 SOLD
1992 Legacy SS 5mt, with some neat stuff on it
kleinkid
Post by kleinkid » Tue Mar 25, 2014 6:45 am
Way to go! Keep going.
just-rust
Post by just-rust » Tue May 27, 2014 5:50 pm
Looks like July is going to be my month. Sucks. Thought I would have it in sooner. I will update when it happens!
I picked this up to run out to the BPV:
http://www.ebay.com/itm/370592608574?it ... m=&vxp=mtr
Not sure if it will be optimum with a 45 degree, but it should work good!
just-rust
Post by just-rust » Wed Aug 06, 2014 3:09 am
*edit* Installed this today! A write-up is soon to come. 9/8/14
just-rust
Post by just-rust » Sun Sep 28, 2014 2:32 am
Finally have the photos to show for this. After I pulled my head out of my ass it all went together pretty good.
Please note that installation is for a VF11.
Picking up where I left off - I needed a 90 degree 1.75 to 2.00 inch reducing elbow to connect the turbo to the GrimmSpeed silicone. I also used a silicone joiner for these.
http://www.ebay.com/itm/1-75-2-90-ELBOW ... 2b&vxp=mtr
http://www.siliconeintakes.com/turbo-pi ... p-110.html
The 90 degree that came with the GrimmSpeed kit fit with an inch and a half cut off of the long end and then tightened this end onto the metal y-pipe. This allowed the short end of this hose to be rotated up to connect to the 90 degree reducing elbow that goes to the turbo. Please refer to the pictures for the angles that worked.
Here are the all angle shots:
Here are the shots of the 90 degree reducing elbow showing the final length of each side going into the bend.
On the reducing coupler, from the 1.75" side, I had about 2.5" of straight hose going from the turbo to the bend and about 1.5" leading down into the Grimmspeed hose on the 2" side.
After that, double check everything is tightened down on the intercooler and then align the turbo pipe and nudge it on while putting the intake side into the manifold coupler. Snug it in and hold it while tightening the clamps snuggly to assure proper alignment. Then tighten it fully on the intake and the turbo side and call it good!
One trick I did towards the end was to put a t-bolt clamp around the silicone hose and use it as a guide for a straight cut around. Previously, my cuts were jagged and wonky.
Also watch where your clamps are aligning so they aren't rubbing on any hoses. I sliced the coolant hose that runs to my turbo the first run because I neglected to watch out for any problem areas the clamps may cause.
BPV hook-up goes from 1.25" to .75".
Please double check all measurements before cutting and fitting. It takes multiple times mounting, measuring, then double checking and re-measuring to assure this goes on properly.
If you do this and I left something out please update the thread.
Post by Legacy777 » Sun Sep 28, 2014 10:01 pm
That's a good tip for cutting silicone hoses. I could have done a better and used this trick when I did my intercooler.
1997 Impreza OBS
