»  BC-BF Legacy Discussion »  Intercooling
#awic and throtle body oil cooler
Custom Search
Login | Register
Post new topic Reply to topic  [ 5 posts ]
Author Message
 Post subject: awic and throtle body oil cooler
PostPosted: Tue Oct 01, 2013 2:47 am
I tried sniffing around through the forum first but....
good and or bad idea? im building the intake tubing and awic plumbing and just had a thought?
what if I ran the awic water through the oil cooler and thought what if I run it through the throttle body connection?
would it heat the intake more than normal? only after 300 hp or so. . it wont be a race car
tell me what you guys think.. thanks
'92 TW "Hana" ej20tt obd1 <too many to list< sold :-( bought back :-)
Profile  Offline
 Post subject: Re: awic and throtle body oil cooler
PostPosted: Wed Oct 02, 2013 10:37 pm
Here's my thoughts:
The oil cooler would try to heat up the coolant to oil temperature, and the AWIC heat exchanger will attempt to fight that temperature change. I'd imagine you'd want your awic coolant far cooler than engine oil temp, but you definately don't want engine oil running cooler than proper operating temp.
The throttle body coolant lines are there to prevent freezing of the throttle body in cooler weather. Air passing through it has virtually no time to be heated up by the throttle body, due to how fast it's flowing. In warmer climates people actually bypass the throttle body.
These are my non-engineer opinions ;)
Profile  Offline
PostPosted: Wed Oct 02, 2013 10:57 pm
Thanks for the reply as I kept fighting my thoughts in my head. Prob the best if I left it alone. How about the idle air control valve. Would u want to bypass that as well as the tb?
Thanks for advising. :wink:
Profile  Offline
PostPosted: Thu Oct 03, 2013 8:11 pm
I bypassed my iac for a year or two. I dont recall noticing any advantages with it bypassed. With the coolant lines hooked up, first start of the day, it idles at 1500 a little less in time before the car jumps down to its 750 rpm warm idle.
Sent from my SGH-T889 using Tapatalk 4
Profile  Offline
PostPosted: Tue Oct 08, 2013 9:21 pm
I wouldn't recommend bypassing the IAC valve unless you have a problem that requires it.
1997 Impreza OBS
Profile  Offline
Who is online
Users browsing this forum: No registered users and 1 guest
Panel
Search for:
Jump to:
 cron
Dizayn Ercan Koc
