06-07 tmic install woes
Posted: Tue Feb 10, 2015 10:37 pm
by familywagon
I've done plenty of searching and seem to be having a little issue with my tmic install.
I've lowered all of my lines under the pitch stop and the tmic y is still hitting my a/c line. From all of the pics I've found seems like I'm the only one with this issue and having the goofy a/c line. Most lines I've seen don't have that round cylinder type piece on it.
Any ideas?
Re: 06-07 tmic install woes
Posted: Tue Feb 10, 2015 10:40 pm
by bcmaxx
My line looks different! , possibly dealer installed a/c? can you bend the line at all? my 02ish wrx tmic didnt come close to the a/c lines at all
Posted: Tue Feb 10, 2015 10:49 pm
by familywagon
It's a factory ac car. My buddies 92 ss has the same thing on his car.
Posted: Wed Feb 11, 2015 12:36 am
by bcmaxx
th3e only difference I can see is a different part number jun 93 production and newer. 73045aa311 up to 0593 , 73054aa410 06/93 + , even the evap core is different for the latest model year. surely you can at worst disconnect and reclock it or make a bend in the alum. pipe?
Posted: Wed Feb 11, 2015 1:16 am
by mike-tracy
The factory turbos all have a kinked line like that. The part number difference is when they went to R134.
The solution is to grab a non turbo line off a legacy with the same brand ac compressor as yours. Non turbos could come with 3 or more different compressors so that has to match.
Posted: Wed Feb 11, 2015 5:05 am
by 94Sport
I'm doing the same thing as we speak. Cleared the AC line but hitting the coolant reservior. How did you did you relocate that?
Posted: Wed Feb 11, 2015 5:24 am
by familywagon
My,buddies 92 ss has the same cylinder thing on the line. So it must be a non turbo thing.
I'm trying to do it without having to disconnect the line and lose all that precious r-12. I did think of putting a kink in it. I may end up doing that.
I clocked it 90° and built a bracket. Looks pretty nice actually, almost factory. Uses factory mounting holes also.
Posted: Wed Feb 11, 2015 6:48 pm
The thing I can suggest is slightly loosening the fitting just enough to rotate that line downwards just a little bit to see if that gives you a little more clearance.
Are you needing a little bit or a lot more clearance to get things to fit?
As for the coolant expansion tank, most people relocate it using a newer style metal WRX tank. I rotated mine with my AWIC setup, but I did not have the bypass valve on the intercooler to get in the way.
Posted: Wed Feb 11, 2015 7:06 pm
by familywagon
I just need a little bit, 1/2 to 3/4 of a inch. I have loosened the fitting in order to rotate. Just need a little more. May need gteaser to come by and help.
Posted: Mon May 11, 2015 1:45 am
by familywagon
Been super busy with work lately bit i fanally got it on. Getting some sort of vibration or air type noise from 0-4 psi. It almost sounds like a balloon loosing air. I make full boost so I don't think it's a boost leak. The intercooler also slightly rubs the hood. Still demons I gotta work out.
Posted: Mon May 11, 2015 2:52 pm
by cj91legss
That balloon sound is a boost leak.
Intercooler looks great!
Posted: Mon May 11, 2015 2:55 pm
by familywagon
It only happens at low boost though...
I've double checked everything. I'm starting to go crazy with this.
Posted: Tue May 12, 2015 1:48 pm
by cj91legss
Had a similar issue with my 93. Hissing at low boost. I tried to find it every way possible. Then when I pulled the engine out and started breaking it down, I noticed several cracks in the intake tract post turbo. Did you inspect your Y-Pipe before installation?
Posted: Tue May 12, 2015 10:52 pm
by familywagon
Yea. Y pipe is completely custom made by me. Everything has been tightened and checked. :(
Posted: Fri May 22, 2015 3:46 am
by just-rust
Intercooler looks awesome. Glad it is in and the AC line is cleared. I also had the same deal as you and it turned out to be a leak at one of the joints on the y-pipe. Everything looked and felt fine but just needed to be readjusted. Definitely a pain the first few times installing.
Posted: Fri May 22, 2015 3:51 am
by cj91legss
I have never done a tmic. It looks awesome, but I never got the opportunity. I jumped straight to a greddy front mount cuz I got a deal.
Report back and let us know how your setup is doing broski.
Posted: Wed Jul 01, 2015 12:26 am
by subiedoutlegacy
I'm installing mine and wonder how I relocate the hose off the inlet that goes to the charge pipe to the throttlebody. Right now doing a robtune 550 and installing an 06 intercooler. HELP ='(
