»  BC-BF Legacy Discussion »  Intercooling
#06/07 tmic vs slanty
Custom Search
Login | Register
Post new topic Reply to topic  [ 7 posts ]
Author Message
 Post subject: 06/07 tmic vs slanty
PostPosted: Sun Mar 08, 2015 10:48 pm
i finally got around to putting on my 06-07 tmic and its like night and day. dont know if the slanty was leaking but the car is more responsive and the spool sound is more present. is this normal between the to styles?
Profile  Offline
 Post subject: Re: 06/07 tmic vs slanty
PostPosted: Mon Mar 09, 2015 12:07 am
Yeah i noticed the responsiveness increase as well. The black plastic accordion hose on the slanty kills the flow. So the 06/07 floes better and intercools better. Win win! Now if i could just keep the coolant tankn in the stock location...
Profile  Offline
PostPosted: Mon Mar 09, 2015 1:06 am
i have a wrx coolant tank in the oe area this set up pulls hard at 10 psi lol. i turned the boost down a tad just to be safe
Profile  Offline
PostPosted: Mon Mar 09, 2015 2:45 am
I'm not sure what turbo you have, but a td04 or similar should be fine on the stock injectors, ecu etc, at just under boost cut.
Profile  Offline
PostPosted: Mon Mar 09, 2015 3:06 am
jdm td04 fcd and mbc. gonna turn it back up tomorrow
Profile  Offline
PostPosted: Mon Mar 09, 2015 10:25 am
Yeah, the newer TMICs totally rape the older ones. Its a shame we cant readily fit the STI TMIC, that thing is a beast.
Profile  Offline
PostPosted: Mon Mar 09, 2015 1:07 pm
so do t he newer tmic enhance the spool sound?
Profile  Offline
Who is online
Users browsing this forum: No registered users and 1 guest
Panel
Search for:
Jump to:
 cron
Dizayn Ercan Koc
