tmic vac line
Posted: Tue Sep 26, 2017 10:38 pm
by 208ss
So how do you guys route your vac lines with a TMIC. I have a 91 ss that did not come with a TMIC and the person i bought the car from installed one and some of the vac hoses are not routed right. Some are kinked. Other note the car has a wrx 2.0 block with 22t heads. So the vac port up front is not there.
The TMIC is off a 06 wrx I think.
Re: tmic vac line
Posted: Fri Nov 03, 2017 5:43 pm
Are you referring to the crankcase vent lines?
If so, most people figure out whatever way they can route them. However, it's important to keep the modified routing functioning the same as the stock setup.
Re: tmic vac line
Posted: Sat Nov 04, 2017 12:09 pm
by cj91legss
Just out of curiosity, do you have a pic of the car?
There's a vacuum reference diagram on the bottom of the hood. If you follow that and make sure everything is hooked up accordingly, you'll have better peace of mind.
Re: tmic vac line
Posted: Wed Nov 08, 2017 5:43 pm
by 208ss
i will get photos tonight
Re: tmic vac line
Posted: Thu Nov 09, 2017 4:56 am
by 208ss
Re: tmic vac line
Posted: Thu Nov 09, 2017 4:58 am
by 208ss
This mess. Kinked hoses... missing parts?
Re: tmic vac line
Posted: Thu Nov 09, 2017 5:23 am
by mike-tracy
The long out of production factory hoses had nice molded bends in em. I've used those plastic 90* elbows and a T in the appropriate sizes, from autozone.
Re: tmic vac line
Posted: Thu Nov 09, 2017 1:47 pm
by cj91legss
You'll have to use a different photo sharing site. We cant see anything from photobucket.
