»  Marketplace »  Car Lot
#1993 Legacy Turbo Wagon MT swap tdo4 topmount Arizona
Custom Search
Login | Register
No partouts or individual parts sales.
All auctions or local sales should be in the Craigslist/eBay forum
Post new topic Reply to topic  [ 10 posts ]
Author Message
 Post subject: 1993 Legacy Turbo Wagon MT swap tdo4 topmount Arizona
PostPosted: Wed Jul 19, 2017 7:12 pm
93 legacy turbo 195k mi
ej22t closed deck single cam turbo motor
The car has wrx brakes and wheels.
Tires are near new
Lowering springs
TD04 turbo and topmount intercooler
HKS FCD to combat fuel cut
The motor is completely refreshed with all external seals 5k miles ago. f/r main, water pump, timing belt, etc.
Manual Trans Swap,,,,,Tight ratio...not sure exactly what, but not your ideal freeway cruiser as 5th at 80 is 5kish.
new clutch/ flywheel, new rear axles, new driveshaft, matching rear end to the trans ratio.
massive aluminum koyo radiator.
New motor mounts
P/S rack recently rebuilt
magnaflow muffler with custom 3" exhaust w/ 3" high flow cat
manual boost controller---not used at the moment as the turbo has an adjustable spring for waste gate.
Greddy boost gauge
luggage box atop the roof
R134 conversion with cold ac....just replaced compressor as well and recharged. cold as ice
front cv boots, misc poly bushings, trans mount, all the stock exhaust, Valve cover gaskets, stock springs if lifting is what you'd want to do with forester shocks.
She's pretty quick and super fun to drive.
The few oddities...
rear diff ring/ pinion has been winy ever since the trans swap. The backlash is a bit off, but no metallics in the diff fluid
I haven't finished ALL of the wiring with the m/t swap. (no reverse lights, no neutral signal, starter circuit is bypassed, no cruise control)----none of these affect the drivability or put the car in limp mode however.
Need to replace the bulbs for the gauge cluster
pass window switch on driver side is out, but pass works
body has a few dents and dings.....
windshield has had a crack ever since I got the car years ago.
that's about it......
looking 3k.
I really don't want to sell, but just picked up a ej207 v8 gf8 that needs love n I can't keep both.
Profile  Offline
 Post subject: Re: 1993 Legacy Turbo Wagon MT swap tdo4 topmount Arizona
PostPosted: Sun Jul 23, 2017 11:24 am
What part of AZ? A/C compressor itself is leaking? Not a line?
lucas wrote:
There were multiple Legacys with 300k+ miles. Jesus will return on a Turbo Lego.
Profile  Offline
PostPosted: Sun Jul 23, 2017 6:40 pm
yup, the seals of the compressor wheel went, so needs a rebuild or a new one.
Profile  Offline
PostPosted: Thu Aug 03, 2017 7:22 pm
update: recently installed new compressor and recharged the ac.....blowing cold as ice.
Profile  Offline
PostPosted: Tue Oct 24, 2017 9:32 am
Did you sell this already?
Profile  Offline
PostPosted: Tue Oct 24, 2017 5:38 pm
I still have her ripe n waiting for ya
Profile  Offline
PostPosted: Tue Nov 14, 2017 6:36 pm
Someone buy this pls .
2500 obo
Profile  Offline
PostPosted: Wed Nov 15, 2017 1:49 am
If only you were closer
Profile  Offline
PostPosted: Mon Nov 20, 2017 6:43 pm
I'm trrying to convince my wife currently.
Profile  Offline
PostPosted: Tue Nov 21, 2017 7:42 pm
I'm from Montana. $2000 and I'll drive down to get it this weekend.
Profile  Offline
Who is online
Users browsing this forum: No registered users and 1 guest
Panel
Search for:
Jump to:
Dizayn Ercan Koc
