FS: 94 Subaru Legacy SS 5 Speed -Re-Post- $2500.00 UTAH
For sales of complete cars only, from body shells to full builds, running or not.
(Legacy Central BBS is not responsible for any arbitration between its users relative to this forum. Play nice and deal straight)
No partouts or individual parts sales.
All auctions or local sales should be in the Craigslist/eBay forum
Tbly89
Post by Tbly89 »
I am re-posting my 94 SS.........I had it sold but the deal went bad..................
I have my 94 legacy SS up for sale. It has the manual 5 speed with some WRX parts. The reason I am selling it is because I need a truck to haul my stuff across country. I love these cars but I don't have the time or space or knowledge to work on this project and will be moving in a year or so. Now that being said, this car is a great platform to start with if you know what your doing. I use it daily, and my commute to work involves climbing up a canyon road in snow and ice conditions up to 8,000ft elevation with out problems.
I bought it back in July, after having it for a couple weeks I started to work on things that needed attention. Most of the vacuum lines were connected wrong, a wheel bearing was completely gone, and other little things also got accounted for and fixed like the thermostat, ignition coil, axle seals. I also had to do sway bar links on the front, a tie rod end, and 4 wheel alignment.
The car sits on 4 brand new all season tires 90% life with aftermarket rims that I have no idea the name of but they look pretty cool. I have made two trips to Lake Tahoe (1000 miles both ways) this winter and the car does fine! What the car doesn't do properly is idle......Every sensor has been tested, checked, adjusted. No CEL, and everything MAF, IACV, KS, TPS, CTS, 02 sensor had a professional test and check.
MODS
+ 3" Turbo BK Exhaust w/ Flow Master Muffler/sounds very deep and throaty.
+ TD04 w/ no shaft play, clean and in good condition.
+ 06 WRX TMIC/good shape, y pipe is put together/modded well no leaks.
+ Walbro 255 pump.
+ PLX Wide Band
+ Turbo XS BPV H34/Brand new a month ago.
+ WRX Seats front and back.
+ 03 WRX Front and rear struts.
+ Tein S-Tech Springs ( lowered about 1.5")
+ Aftermarket drilled a slotted rotors, breaks have about 85% life.
Here is some older pics. If anyone is seriously interested I can send some updated pictures.......
This is an older pic, I have rebuilt the intake, and added a turboXS bypass valve to the TMIC. Also a optima red top battery.
I love this car but i have to start putting my money toward a truck. Im open to answer any questions and I check the forum all the time. If you want to PM me that's fine too. This Subie needs a home.
Asking 2500.00 I am located in Salt Lake City, UT
Tbly89
Re: FS: 94 Subaru Legacy SS 5 Speed -Re-Post- $2500.00 UTAH
Post by Tbly89 »
Price reduced 2000.00, need it sold.
Post by SILINC3R »
Damn, sorry to hear that. If only you were closer, hope it works out for you this time around
Post by SILINC3R »
Oh and where are you moving to across country? You coming to the East Coast?
Kom3t
Post by Kom3t »
Still availible? Pm me with phone number
DLC
Post by DLC »
I'll have a look at this for anyone :)
Legacy Central
blazewrx
Post by blazewrx »
What do you mean by going to take a look? Do you live near the seller? Also, to the seller is that a dent on the rear drivers side quarter panel? I don't mind repainting the car but really don't want to have to get new panels as well. Have you figured out the idle yet? Does it stay running and just idle all over the place or shutdown on you?
