Stud #2 FALLS Out. *sinking stomach*
So I thought I could hear my valves under boost, which I remember once back when that I had a loose exhaust bolt. So I get the car up and I start to see if any of the three manifold to head bolts on the turbo side needed tightning. The middle one does...and spins ...and spins... then just lets go of the stud ... threads firmly attached around the stud like a slinky...
*insert stomach sinking #1 here*
Then I go to the outside bolts... one is tight as can be, thats good. The other repeats the middle bolt..and births another slinky. Barf City.
So my exhaust manifold is being held on by one bolt thats ACTUALLY in, another bolt that has been lightly tapped back into place with the slinky around it + loctite blue *ashamed*
This engine is next to be resealed, right now I'm in the middle of the XT. ...if you're interested
Subaru XT Forum
or just a slew of pics...
XT Photobucket
Got a few minutes?? Slideshow
Ahem... so anyway, Anyone have any ideas that might fix the problem temporarily, until i can get the XT back together, and take the legacys engine out and have the thing to the machinists??
harumph!
Subaru XT Forum
XT Photobucket
harumph!
-Luigi-
....Yes like nintendo
1987 GL10 Sedan 3.700 LSD
1988 XT6 FT4WD 3.900 Diff Lock
1992 EJ22T Touring Wagon 5MT Swap 4.111
Re: Stud #2 FALLS Out. *sinking stomach*
ive never replaced the stud but id probably cut just the nut off andand use a pipe wrench to get the stud out?
No no... the stud FELL OUT. As in I looked up into the hole where i should see threads in the aluminum, but all i see are slick shiny NON-threaded walls.... the stud has nothing to grip... until i take the engine out, and get the heads machined and new STEEL drop-ins because threads in aluminum is insane... insane!
-Luigi-
re-tap it or use a helicoil for now till u get the motor out.
helicoil
helicoil
Helicoils get a bad rap for some reason but if used correctly are badass.In reality you are better off with them in place of aluminum threads anyways.12mmx1.25 is what you need for those i believe.Napa should have a kit right there.
NuclearBacon wrote:The other repeats the middle bolt..and births another slinky.
I dunno why but that line had me crackin up!
HeliCoils are great. Actually all the bolts holding my oil pump in place on my metro engine are helicoiled lol. I've always had great success with helicoil. I've only done them in aluminum though. But the block is aluminum so you should be good to go.
anyone want to second this size before i run down? PERFECT everyone! thank you!!!gijonas wrote:He12mmx1.25 is what you need for those i believe.
-Luigi-
$42.99 for the kit...
WOAH online they're like $150 (looks like 24 pieces or something) Hmm... okie dokie!
-Luigi-
Did you get it from harborfreight? They have ten "helicoil" inserts for 3.99 if you need other sizes
I haven't purchased it yet. But i did find This: Harbor Freight Helicoil
And also this: How to Install a Helicoil
I called around and an obscure napa in town finally had one for the $42. I assume the kit has the drill bit, the tap, and the helicoil setting tool.
-Luigi-
thats not the correct size, its a 10x1.25 if i remember correctly
*sold*
*sold*
I got mine at autozone and I believe it was cheaper than that. I want to say more like $18. Comes with like 10 helicoils and the bit.
20$ sounds about right,And yes they may be 10 rather than 12mm
SO! took my micrometer out and the bolt is a 14mm, the Inner diameter of the hole was about 9.9## so yeah, its 10mm.
10X1.25
Autozone has them for $29.99 (the kit)
Kragen/O'Rileys has them for $24.99
10X1.25
-Luigi-
