Header Fitment questions
I have seen a few threads about Header fitment and how a shop will have to weld up a new pipe for the cat section. What options are there for headers?
If I took these into a shop would they be able to make them work?
http://www.speedyracer.com/servlet/the- ... for/Detail
1996 Subaru Legacy L
1993 Subaru Legacy SS
1992 Subaru Legacy L
1990 Subaru Legacy L
Re: Header Fitment questions
I'm assuming this is for a non-turbo car.
There isn't any stock headers that will fit without modification of cat section.
Yeah, it's for a 92. Has anyone had this done and know the rough cost to have the shop install the headers and redo the piping to make them work?
white91wagon
Its going to cost quite a bit to fab up something for those ones. I run theses ones on my 91 legacy and have had good luck with them so far. Good sound, some fitting issues, but great for the price. They are a direct fit which will cut down on cost. Also give a great deal more flow over stock. If you peel away all the shielding the stock manifolds are pretty constrictive IMO. Especially at the small Y right out off the head flange.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 818wt_1002
Also if you want to go a little wild these are so sweet! Wish i had got them instead
http://www.subarugeneration.com/OBX-EXH ... header.htm
Those are equal length how do they sound?
And it would really cost that much to use the UEL's that I posted?
Those headers look wierd to me. Is that a mirror image or does the exhaust go out the opposite side on NA cars versus our turbos?
1990 NA 2.2 Open Light rally car
The ones I posted? Or the Magnaflow ones?
The other ones are built for the Dual Port EJ22's and EJ25's on the 2nd Gen Legacy. Our cat placement is different then the first gens.
I was wondering what could be done. She wants sound and no EL headers.
yeah i meant the ones in your original post. Iv never seen a set up like that, but then again i dont have any experience with other gens of legacy.
Any other options for UEL? Or any at all?
if you brought in the header, cat, muffler
i would expect to spend ~200$ to have a shop fab the rest.
UEL you can go with aftermarket EJ25 headers but you'll need to buy the cat + have them customize the rest
92 Legacy L, AWD Auto. 94k miles purchased in May 2011 for 250 bone$
It starts...
It starts...
Just doesnt seem reasonable to get a full headerback on these cars.
WRXish
I would very much like to have an equal length header and free flowing cat to go with the custom cat back I had put on a while back. I have no doubt it would wake it up a bit. What works on a 91 2.2?
Yeah a later aftermarket dual port header with a fabbed up cat section would work. What they're saying above is there's no header that bolts to our factory cats.WRXish wrote:I would very much like to have an equal length header and free flowing cat to go with the custom cat back I had put on a while back. I have no doubt it would wake it up a bit. What works on a 91 2.2?
