catless downpipe options.
I'm looking for a catless down pipe . What's is the best plug n play? I want to just stick it in with no mods if possible. I'm still running the stock turbo exhaust. So what's my best bet?
Uriel
1994 N/A Sedan-Daily driver
1994 Touring Wagon 4EAT-Project car #1
Re: catless downpipe options.
You wont be able to stick one in with no mods. You will have to have some sort of reducer installed if you want to keep the stock catback. It will also need to be able 6-8 inches in length.
scoobydoo94turbo
so which front down pipe will fit followed by modification of the mid pipe?
05 Forester XT 2.5L Turbo DD 250,000km R.I.P
94 Legacy Turbo Touring Wagon 412,000km ) R.I.P
91 Legacy Sport Sedan 136,017km (parts car) R.I.P
04 Impreza TS Wagon 230,000km timing idler failed, being rebuilt!
94 Legacy Turbo Sedan 285,000km Mint DD
ditch the stock exhaust and just go three inch turbo back. How i run mine passed emissions in CA twice. then i moved to not communist washington always passes.
1993 legacy ss "Shela"
scoobydoo94turbo
Reason im asking what just bolts up is I already took a mid pipe off another legacy turbo cut the cat out, added in a 1ft piece of pipe so if I could find a downpipe that just drops in and will line up with the existing pipe I already made I have no problem cutting an reducing it etc to fit..
i think most will "fit" but not as plug and play as you want. Mine had to be shortened at the bottom end.
Hi,
The '02-'07 WRX/STi should be the correct length, but you'll need one of these:
This will connect to your stock exhaust and allow it to connect to an aftermarket downpipe's flange. CAREFULLY remove the donut gasket and move to the adapter....or better yet, get one b4 the swap and be prepared.
Td
Td
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
The picture is not showing up. Is that the Grimmspeed adapter?
http://www.grimmspeed.com/3-downpipe-ad ... u-catback/
that be it.
Probably cheaper on eBay or other online source.
that be it.
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
