»  BC-BF Legacy Discussion »  Exhaust
#aftermarket up pipe to replace craked and leaky ss up pipe
Custom Search
Login | Register
Post new topic Reply to topic  [ 5 posts ]
Author Message
 Post subject: aftermarket up pipe to replace craked and leaky ss up pipe
PostPosted: Sun Mar 30, 2014 11:18 pm
just wanted your guys opinions on this the up pipe on my ss started leaking at where i thought was the gasket but one i go to crawl under my car i notice its got a giant crack in it soooo its needs replacing i have no access to a welder or anything unfortunately would this wrx cat less up pipe work as a replacement i really don't wanna get rid of the stock exhaust manifold setup for an aftermarket header from what iv read it kills turbo spool and you lose torque but i need this fixed sooon its terrible heirs a pic of the up pipe
88 Honda civic wagon B20VTEC SWAP-RIP
85 Subaru loyal sedan-SOLD
95 Subaru impreza $500 BEATER-SOLD
91 Subaru legacy SS jdm ej20g swap
CHECK OUT MY ej20G BUILD HERE>> viewtopic.php?f=25&t=53766
Profile  Offline
 Post subject: Re: aftermarket up pipe to replace craked and leaky ss up pi
PostPosted: Tue Apr 01, 2014 2:38 am
My recommendation would be to try and find an STi up-pipe. They are identical to the turbo legacy up-pipe. I didn't have good luck with an aftermarket up-pipe. It even had a flex joint, but I couldn't get it to fit. Not saying the one above won't fit, but if I had a choice, I'd go back with the stock up-pipe.
1997 Impreza OBS
Profile  Offline
PostPosted: Tue Apr 01, 2014 7:50 am
yeah i hear ya im no fan of aftermarket headers or junk on ebay i just cant find any parts around here in Spokane WA an sti up pipe sounds like my best bet i wish i could just get mine welded up and put back on but i cant afford down time on my car atm :( i won the bid on this downpipe for $45 so well see how it works if it does fit im gonna work on getting my stock SS down pipe fixed just cant do anything with it until its off the car i hate being in a position like this thanks for the input :smt023
Profile  Offline
PostPosted: Thu Apr 03, 2014 6:30 pm
You're welcome. Hopefully that one will work for you in the mean time so you get the stock one repaired.
1997 Impreza OBS
Profile  Offline
PostPosted: Thu Jul 24, 2014 8:10 pm
Let us know how the fitment of this ebay pipe is, im in the same situation, i have 3 spare pipes but all leak when i hook it up to my smoke tester at the flex joint..
05 Forester XT 2.5L Turbo DD 250,000km R.I.P
94 Legacy Turbo Touring Wagon 412,000km ) R.I.P
91 Legacy Sport Sedan 136,017km (parts car) R.I.P
04 Impreza TS Wagon 230,000km timing idler failed, being rebuilt!
94 Legacy Turbo Sedan 285,000km Mint DD
Profile  Offline
Who is online
Users browsing this forum: No registered users and 1 guest
Panel
Search for:
Jump to:
Dizayn Ercan Koc
