»  BC-BF Legacy Discussion »  Engine
#machine shop
Custom Search
Login | Register
Post new topic Reply to topic  [ 11 posts ]
Author Message
 Post subject: machine shop
PostPosted: Sun May 13, 2018 2:09 am
I didn't know where else to put this haha
I'm in gathering parts really fast for my engine build, so I need to find a good machine shop to get my work done at. I'm located in enumclaw, wa, but I'm willing to drive a bit if it's worth it. Thanks in advance!
Kris
'91 Mica White SS - R.I.P.
'91 Black SS - SOLD
Profile  Offline
 Post subject: Re: machine shop
PostPosted: Tue May 15, 2018 7:02 am
Not sure if you’d want to drive all the way down to chehalis, but Barry’s Quality Machine down here here is pretty damn good.
Profile  Offline
PostPosted: Tue May 15, 2018 5:56 pm
I used Bearing Service Co in Portland, Oregon when I had the machine work done for my stroker 2.2. For the 2.0 I’m going to be using Gibson performance in Spokane, Washington.
91 black SS 5 speed.... 300k on engine.
93 silver TW 5 speed... Track car project
73 kazen red VW bus riviera camper
Profile  Offline
PostPosted: Tue May 15, 2018 10:22 pm
i dont mind chehalis, ill look it up.
portland and spokane seem a little far, butill keep it in mind!!
thanks everyone
Kris
'91 Black SS - SOLD
Profile  Offline
PostPosted: Mon May 21, 2018 5:47 pm
Make sure the machine shop is very familiar with Subaru motors and whether they use a torque plate when machining, etc.
1997 Impreza OBS
Profile  Offline
PostPosted: Mon May 21, 2018 10:38 pm
awesome, thanks for the info josh!!
Kris
'91 Black SS - SOLD
Profile  Offline
PostPosted: Tue May 22, 2018 4:25 pm
Torque plates in place of both heads and a line bore of the crank mains. Don't rebuild a turbo Subaru block without doing this.
1975 Superstar Wagon
1984 GL-10 Turbo-Traction Wagon
1984 GL-10 Turbo-Traction Hardtop
1987 RX coupe
1987 RX Type RA
2002 WRX sedan
Profile  Offline
PostPosted: Tue May 22, 2018 6:05 pm
I don't know whether the machine shop I used to rebuild my motor used the torque plate or not. I found out about that afterwards. Which is why I suggest using someone that really knows Subaru motors.
1997 Impreza OBS
Profile  Offline
PostPosted: Tue May 22, 2018 7:17 pm
I've had a couple blocks done at Action Machine in shoreline. Very professional, and I believe they use a torque plate if you ask.
Profile  Offline
PostPosted: Wed May 23, 2018 2:50 pm
I and a friend have used Action Machine in the past as well, with good results. This is when they were still in Kirkland though, not sure what has changed since they moved.
1987 RX coupe
1987 RX Type RA
2002 WRX sedan
Profile  Offline
PostPosted: Wed May 23, 2018 5:28 pm
ill look into them, thanks!!
Kris
'91 Black SS - SOLD
Profile  Offline
Who is online
Users browsing this forum: No registered users and 2 guests
Panel
Search for:
Jump to:
Dizayn Ercan Koc
