»  BC-BF Legacy Discussion »  Engine
#Starts but wont idle
Custom Search
Login | Register
Post new topic Reply to topic  [ 5 posts ]
Author Message
 Post subject: Starts but wont idle
PostPosted: Mon Nov 05, 2018 12:12 am
I have a 91 Legacy non turbo that wont idle period. It's not giving a cel, but it will run just fine when the gas is given through the pedal. I've taken the iacv off and cleaned it and it still wont idle at all I've tried to check all the vacuum lines i can see and none of them look cracked. At this point I'm completely stumped and the only way to get it to idle is by adjusting the throttle cable.
Profile  Offline
 Post subject: Re: Starts but wont idle
PostPosted: Tue Nov 06, 2018 7:30 pm
Out of curiosity, does your throttle body have one of these adjustment screws in it?
https://experiencetherave.com/subaru/images/TB
If it does, you could try adjusting it. I would caution you to make sure you count the number of turns you make so you can put it back to where it was in the event that is not the issue.
Unless you cleaned the throttle body or did something else adjusting this screw is still going to be fixing a symptom vs. the cause. Did the car ever idle correctly?
1997 Impreza OBS
Profile  Offline
PostPosted: Wed Nov 07, 2018 1:59 am
Yeah it's always idled correctly, a little rich when cold but before this all happened it would idle just right and go through the warm up process. My throttle body doesn't have that screw though, right where it should be is just a hole.
Profile  Offline
PostPosted: Fri Nov 09, 2018 9:42 pm
Could be as simple as a fuel filter
Profile  Offline
PostPosted: Wed Nov 21, 2018 7:37 pm
So what changed between it idling correctly and not idling correctly?
1997 Impreza OBS
Profile  Offline
Who is online
Users browsing this forum: Google [Bot] and 2 guests
Panel
Search for:
Jump to:
Dizayn Ercan Koc
