I'm trying to diagnose a slight hesitation at low RPMs in my car and i am going to try to replace the spark plugs to see if that will help.
Any suggestions on what brand or type i should use...? I'm just looking for some cheap efficient spark plugs... no performance plugs or anything fancy...i just want some that will run good on my Legacy...
Spark Plugs
Spark Plugs
209,000 miles!
2002 Impreza WRX Sport Wagon
209,000 miles!
ditto on the ngk coppers
- quasi-mod-o
I know this is an old topic, but I've got $.02 and I want to spend it here! I have tried the Bosch Platinum 4's and I saw absolutely no increase in performance, only a worsening of gas mileage. I was told that German plugs have colder heat ranges designed for German cars, therefore leave German plugs to German cars, and Japanese plugs to Japanese cars...
I have since put NGK coppers back in, and find performance to be just as adequate. I do have Magnecor 80mm wires though, and I recommend those!
2000 Subaru Legacy B4 RSK
*Formerly DerFahrer*
WHOA!!!I do have Magnecor 80mm wires though, and I recommend those!
those are huge! 80mm = 8cm which = approx. 3 inches.!! those are some huge friggin plug wires!
j/k, i know you meant 8.5mm. that is what the magnecore are. i bouth 7mm ngk wires, they are blue and nice
92 Legacy Turbo \ 5MT \ Silver
Dude.....I got the 100mm wires.....they ROCK!!!
hehehe....j/k
hehehe....j/k
- quasi-mod-o
um...oops , shoulda sat down and thought about that one...Magnecor 80 series, the blue ones...
