»  BC-BF Legacy Discussion »  Engine
#Sticky Compilation Thread
Custom Search
Login | Register
Post new topic Reply to topic  [ 17 posts ]
Author Message
 Post subject: Sticky Compilation Thread
PostPosted: Tue Mar 01, 2005 4:29 am
I've gotten tired of looking at oodles of stickies, so all the sticky'd threads will be linked in this one thread.
EJ22T Swap into NA Legacy - The List....
Notes on the Ej22T!! - More info added!!
Engine Pull and rebuild tips.
Is my motor an interference motor
Engine Light coming on/off
Hesitation. starting to think it's a big problem.
Unexpected cure for my hesitation problem!!
"Grounding mod" - Major Improvements!
Your Fuel Economy
Turbo cooling system diagram
DIY WRX coolant tank relocation and install
The DOHC installation 'unspoken' details thread
Legacy EJ20G Valve Cover Gaskets!
Engine Compression Testing Values
EJ20K Valve Cover Gaskets - Inner
2.5D or Frankenmotor Swap Info
Fried/Burnt Fuel Pump Connector Info
The PCV System Explained
Hydraulic Lifter Bleeding How-to (video)
Useful EJ22T Engine Part Numbers and Prices
DOHC Timing Belt with counting teeth
A radiator upgrade for the 90-94 non-turbo Legacies
1997 Impreza OBS
Profile  Offline
 Post subject:
PostPosted: Tue Mar 01, 2005 4:49 am
awesome, it's about time :)
Do you fold?
Profile  Offline
 Post subject: Re: Sticky Compilation Thread
PostPosted: Tue Mar 01, 2005 7:02 pm
Stratified
Legacy777 wrote:
Is my motor an interferance motor
Might want to double check the dictionary on how to spell "interference". :wink:
Profile  Offline
PostPosted: Tue Mar 01, 2005 7:32 pm
I just copied & pasted titles from the original threads, and didn't bother checking. It's fixed now.
1997 Impreza OBS
Profile  Offline
 Post subject:
PostPosted: Thu Jan 25, 2007 11:04 pm
interference motor thread gone?
-jason
Scoobyniteowl wrote:
Chasin' @$$ is a great form of exercise and if you do get any, then that is more exercise
Profile  Offline
 Post subject:
PostPosted: Thu Jan 25, 2007 11:27 pm
It was moved because of misinformation in the thread. If someone wants to start another one, I'd re-link it.
Legacy Central
Profile  Offline
PostPosted: Mon Feb 25, 2013 1:32 am
I feel like ej22t and N/A Head bolt torque specs should be easily noticable on this list.
Profile  Offline
PostPosted: Mon Feb 25, 2013 3:30 am
Do you have a thread with this info?
1997 Impreza OBS
Profile  Offline
PostPosted: Mon Feb 25, 2013 4:45 am
I searched and searched for 45 minutes today, everythig i found was " torqued to sepcs per haynes manual. " my conversation with stephen today said that that wasnt tight enough.
Profile  Offline
PostPosted: Mon Feb 25, 2013 6:24 pm
The torquing procedure pretty convoluted, and is in the FSM you can d/l from me.
If you use ARP studs, the torque specs are going to be different.....and some shops use a different set of torque specs for the stock head bolts.....
1997 Impreza OBS
Profile  Offline
PostPosted: Mon Feb 25, 2013 6:45 pm
Yeah thats what I heard as well. Trying to find out what their specs are. Reason being i just did a head gasket job and the gasket failed instantly. Went off haynes for torque on NON OEM h/g (not my choice) so im trying to see what other torque specs there are.
Profile  Offline
PostPosted: Sat Mar 02, 2013 6:07 pm
CJ, here is the latest and greatest from Subaru: (see second post)
http://sl-i.net/FORUM/viewtopic.php?f=5 ... rque+specs
I've used this procedure on 3 different engines, including my SS, with no problems whatsoever. About 60k combined miles. Lord Flashheart is a character, but I PM'd him first and he verified that his shop got these from Subaru last year, and he's used them on many, many engines without a single failure (related to HG's).
Profile  Offline
PostPosted: Sat Mar 02, 2013 6:39 pm
I see that is for DOHC, or does that matter any more?
Profile  Offline
PostPosted: Sat Mar 02, 2013 8:09 pm
The steps of backing off the bolts halfway through torquing them down makes no sense to me.
Profile  Offline
PostPosted: Sat Mar 02, 2013 8:46 pm
Ahh. I didn't catch that you were working on an SOHC. I believe they are different, and I just asked Lord F for them. I noticed my 95-99 Legacy Haynes manual has radically different torquing procedures and specs for DOHC than OEM for DOHC.
Yeah I don't know about that. Like I said, I haven't had a problem with the newest "official" technique by doing that.
Profile  Offline
PostPosted: Sun May 19, 2013 3:55 pm
theres one for the sticky
Profile  Offline
PostPosted: Sun May 19, 2013 4:48 pm
Added to the first post.
1997 Impreza OBS
Profile  Offline
Who is online
Users browsing this forum: No registered users and 1 guest
Panel
Search for:
Jump to:
Dizayn Ercan Koc
