fuel pressure
fuel pressure
So what should our fuel pressure be? I just got a pressure gauge that reads to 100 psi and I want to test and see if my pressure regulator is going out, but I'm not sure what the pressure should be. Does anyone know?
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
2014 Volvo S60 T5
So if I rev up the engine should hte psi go up? Cause it goes up slightly and then drops back down to the idle almost right away, even if I'm sitting at 3k-4k rpms.
2014 Volvo S60 T5
2014 Volvo S60 T5
Also I'm sitting at 31 psi at idle. Granted, this is with my car acting fine, I want to get it to act up and then see what it is doing.
2014 Volvo S60 T5
2014 Volvo S60 T5
it should stay constant, the slight increase is nothing to be worried about.georryan wrote:So if I rev up the engine should hte psi go up? Cause it goes up slightly and then drops back down to the idle almost right away, even if I'm sitting at 3k-4k rpms.
#82 M4 TRSCCA Rallycross
http://bbs.legacycentral.org/viewtopic. ... l+pressure
Fourth paragraph.
Your fuel pressure is based upon engine vacuum. If your vacuum at idle and 3-4k is similar, then fuel pressure should be similar.
Fourth paragraph.
Yeah, the wires you speak of aren't the problem. I've already routed them around that connector. If they were the problem my car would die, not sputter.Legacy777 wrote:http://bbs.legacycentral.org/viewtopic. ... l+pressure
Fourth paragraph.
I have about 31 psig at idle, 41 without the vacuum line connected on the fuel pressure regulator. I wish my car would act up again so I could see what it was doing then. I also wish I was able to bring that fuel pressure gauge into the cab of the car, but I sappose that isn't very safe.
2014 Volvo S60 T5
2014 Volvo S60 T5
